Deleted User 298457
Deleted User 298457
Nope there is no such thing as a 1.4 or 1.3 cable. All HDMI cables are the same.
The only difference with standard HDMI cables is you can get high speed ones which support resolutions of 1080p and above (most support this anyway).
See here: http://www.hdmi.org/consumer/buying_guide.aspx
It is a common mistake that HDMI cables come in different versions.
The main difference between HDMI is the quality over length. It suffers massively from signal degradation, hence why 20' cables are quite expensive.
Surely it is the most common monitor connection.
