ssd's are faster than any mechanical hdd so yes it will
Yes, I have a 120GB OCZ drive on my P5K, the speed is incredible.
Not quite as black and white as that is it... ie: If you MB can't make use of the extra speed...
That's a similar spec MB to mine isn't it? Did you move from a regular HD to a SDD one? And you notice a difference?
What SDD would you recommend?
It actually as as black and white as that, SSDs have faster throughput and near enough 0ms seek times.
The Crucial M4 is a popular choice, I have the OCZ Agility 3 and it's spot on though. And yeah the boards are near enough the same. I went from a 1TB Samsung F3, which is one of the fastest 7200rpm drives around, and the speed difference was night and day. Windows boots in 15 seconds flat. I can open Firefox with 6 saved tabs as quick as I can hit the button when it boots up, and within a second it's there![]()
Shouldn't do but I'll let you know tomorrow, I have the same board as you and just got my 240 Mushkin Chronos delivered today.
Think mine is on AHCI already, but not sure.
So how did you get on Guru?
CrystalDiskMark 3.0.1 x64 (C) 2007-2010 hiyohiyo
Crystal Dew World : http://crystalmark.info/
* MB/s = 1,000,000 byte/s [SATA/300 = 300,000,000 byte/s]
Sequential Read : 212.930 MB/s
Sequential Write : 240.637 MB/s
Random Read 512KB : 201.783 MB/s
Random Write 512KB : 239.496 MB/s
Random Read 4KB (QD=1) : 26.241 MB/s [ 6406.4 IOPS]
Random Write 4KB (QD=1) : 66.638 MB/s [ 16268.9 IOPS]
Random Read 4KB (QD=32) : 144.133 MB/s [ 35188.7 IOPS]
Random Write 4KB (QD=32) : 177.156 MB/s [ 43251.1 IOPS]
Test : 1000 MB [C: 15.5% (34.7/223.5 GB)] (x5)
Date : 2012/04/25 20:34:42
