Spec me a ..... Diabetes test meter thingy for blood sugar level
Caporegime
20 Oct 2002
Wish i was in a Ramen Shop Counter
It turns out that a few members of my dad's side has developed diabetes now they are in their 40/50's and although my dad doesn't have it (at the moment), he has asked me to find out if there is something he can buy ver the counter that can test blood sugar level.
What do recommend?
P.s. is this a medical thread?
You can buy them over the counter in chemists. The test strips are usually pretty dear for what they are though.
I wouldn't recommend it tbh. Even non-diabetics can get high readings sometimes, so you may end up scaring yourself over nothing. You can be tested for free at the doctors, or even some pharmacies if you're worried.
There are plenty of over the counter BM kits that work just fine, but go and see a doctor if you're worried. Don't worry about kits until you've been properly tested and have had sound medical advice - a change in diet/lifestyle might be all your dad needs.
i was having bouts of dizzyness and feeling faint, when i was hungry. i grabbed a kit from Boots with the help of the pharmacist.
cost me £14 with a month supply of strips. tested myself when i was having the dizzy turns, and also when i had been eating (after lunch etc)
i had a reading of 13 mmol/L after lunch
and i had a reading of 2.9 mmol/L when hungry
these are high and low compared to the norm, i went to my GP and gave him the results, he took blood tests and after the results i found i had the begginings of type 2 diabetes.
this is all now under control with diet change, but i am glad i got the little monitor from boots.
I testes mine a couple of hours after dinner the other night using my girlfriends kit as she's diabetic and was just slightly high, can't remember what she said it should have been but it was only around .2 over.
If your worried get down to the doctors.
This. He doesn't need a monitor. If he starts getting symptoms (needing to pee a lot, extreme thrust, tiredness), then get it checked out. Or get him to go to the doctors now and get a test done.
You can go years with no symptoms. If it runs in the family or at risk, it needs to be monitored.
It should be monitored by his GP on a regular basis then. Buying a monitor and testing could result in either mis-diagnosis or needless worrying.
It's a waste of a GPs time when you can do it yourself. go get advice and what to look for, but no need to get GP to do it. Or should all diabetics, only get readings from GP?
This. Even a healthy person will have very high blood sugar levels from time to time. Someone gets one of these monitors, they'll just end up convincing themselves they have diabetes. And I say this as someone who actually does have diabetes.
As said before, if you're worried, get a regular check-up with a doctor. Attempting self-diagnosis is worse than useless.
Diabetics do get readings done at clinics every 6 months. As well as checks on their feet, overall diet, eyes and body weight.
He needs to go to the doctors if he's really worried about it and get a test done. If he doesn't have it, then there is nothing to worry about. Since it runs in the family, a doctors checkup every quarter or something like that would be more than adequate.
He will go to the GP, this isn't about that, this is about asking for advice on what kit are best. Which one is easy to use, are the needles all the same, built quality etc. They range from £10 to £40, they can't be all the same quality.
They are all pretty much for a muchness. You have a spring loaded finger *****er and most of them take a standard size disposable lance which you're supposed to use once and discard, but they are fine to use a couple of times unless you've got dirty hands all the time.
So the unit itself; you pay for features like USB connection and data logging, and, more recently, completely pointless features like colour screens which only serve to reduce the battery life and over-complicate a unit that only needs to be very basic. Some of the better ones only need a tiny blob of blood, which means you only need the finger *****er on a light setting. If you have to test several times a day this is a godsend, because you end up rotating which finger you use and if your fingers are cold it can be very difficult to get enough blood out for the cheaper units. Obviously, if you have to use the *****er on a high setting, the lance goes in a long way and bruises your finger.
The physical size of the unit seems to bear little correlation to the price. It's the test strips that work out expensive.
Some of the test strips need you to scoop the blood in the side, and some in the end. Neither are better but you might find one easier to use than the other.
It's a bit of a minefield to be honest and if you need to use one on a regular basis you're going to get through a few before you find one that suits you. Based on what you've said, I'd probably just get a cheap one to see how you get on. At the end of the day, a Type 1 diabetic's life depends on the test meter, so I wouldn't worry too much about their accuracy. You get the odd test strip that is a bit out, but any diabetic worth his salt will realise and either use another test strip or check the calibration of the meter, which you do by the batch number on the pot of test strips.
Edit: Ok, the swear filter doesn't like the word p r i c k e r :D
Nipro TrueOne is a decent glucometer although you buy a new one each time (that comes with 50 strips) rather than just buying strips, but they're only about £20 a time (you need to buy lancets separately)
