Upgrade advice
Am0
Am0
24 Apr 2012
Hi OC'ers
Think I need to upgrade now ;)
Replacing:
Q6600 @ 2.4 Stock
GA-X48-DS5
2x 2GB DDR2 OCZ Blade
Keeping:
EVGA GTX580 DS SC
OCZ RevoDrive 240GB
Windows 7 Home 64Bit
Use my PC mainly for gaming, so would like a CPU thats best for gaming (heard good things about i5 2500k) Also a motherboard that will allow me to overclock (which i may do in the future)
All ideas welcome, price is not really an issue, would like this setup to be running as long as possible.
Thanks, this is my first post :D
Ahhh sorry, I should have been more clear. I only need a motherboard, CPU and memory.
Oh and Heatsink (if stock will not be good enough).
Thanks for the price up guys, would this setup last me a few years? Or should I be waiting a bit for any new hardware planned to come out soon?
With a nice overclock this CPU should last a long time!
Ivybridge [latest CPUs] is out on the 29th, there's some reviews here so you can decide if its worth the wait:
http://forums.overclockers.co.uk/showthread.php?t=18395879
Had a quick read about the IB, doubt I will go for that. I heard that the ASROCK motherboard is very easy to overclock with, and have been browsing this forum and most people recommend gigabyte motherboards, especially the new Z77's. Can I ask why the motherboard thats been recommend here is chosen by you guys?
These CPUs are easy to overclock on any motherboard really, its a case of upping the multiplier and more voltage if you need it - of course for really pushing things its more complex but for most people thats enough.
The Gigabyte one's are solid boards, and perhaps most importantly, Gigabyte have a UK RMA base should anything go wrong :)
A good enough reason for me! Thanks for the help, will be looking to upgrade within 3 weeks. Thanks again.
Cool, no problem :)
Best to pop back and double check before you order as the weekly deals will have changed, and Ivy Bridge will be out [depending on price might be a better buy, or might make the 2500K a bit cheaper].
Yeah, I'll pop back to this thread and ask just to make sure. Oh another thing, I was looking at the Vulcan case, which I believe will need mATX motherboard, (would be easier to take to LAN events) But I'm not 100% sure if I will go down that route, I have a HAF912 atm.
This one:
http://www.nzxt.com/new/products/crafted_series/vulcan
It does indeed need an mATX motherboard, e.g.
http://www.overclockers.co.uk/showproduct.php?prodid=MB-394-GI&groupid=701&catid=5&subcat=2261
