Hi, I did a thread a while back because my Samsung Syncmaster 226 is dying (Takes forever to turn on).. But turned out I didn't have the funds
So now I do and I figure times have changed and i've got a few different opinions.
This is my set up atm.
I am borrowing the BenQ from my folks (a monitor spec'ed to me from here, cheers OCUK). On the left is the dying monitor.
Since borrowing the BenQ I realised it feels a bit small for me. Especially on this desk and considering I was used to the Samsung with a smaller monitor next to it.
I use two monitors for music production, gives me more space but I find it feels odd gaming on just one as its on the right handside, something just doesn't right, like its not as engaging (Does anyone understand what I mean?)
To the spec.
I'm wondering if I should get just one decent sized monitor to sit in the middle or two a bit smaller? :\ (EDIT: since decided one monitor will do, see post 7 http://forums.overclockers.co.uk/showpost.php?p=21769541&postcount=7)
I suppose one might be better as it might make gaming feel a bit better than looking to the right all the time.. and I can always use my other 1440x900 if I want to double and move them around when I go from gaming to music stuff where I require space to move about.
Hope this isn't too confusing.
I don't really have a budget but under £300 would be good. around £200-£250
Thanks guys!
David
Edit: refined what i'm after, check post 7
To the spec.
Thanks guys!
David
