Is this actually true? It isn't in GW1 iirc, you either have to buy them with balth points or buy them.
I do love that feature, being able to make a PvP character at any time is brilliant and I wish more MMOs had it. However as you said its moire a convenience thing and doesn't actually effect the PvP.
Its true in GW2 that barely has any skills which you simply unlock in PVE by using your weapons!
PVP characters in GW2 - all skills available on creation.
Even on PVE characters actually:
http://www.guildwars2.com/en/the-game/pvp/pvp-overview/
When a player takes a character into PvP, they are granted access to all the necessary skills, items, etc. Characters are set to the maximum level, putting everyone on an even playing field. This makes player skill more important than time invested in a particular character. When you take your character back to the PvE environment, you return to the skills and gear you had there, but the game will save your last PvP setup. You'll also be able to store templates for builds. This way, you can try out new stuff in PvP but still easily return to your familiar builds.
Perfect, make level 1 PVE character, play PVP with an equal footing right from the start. I dont think that the PVP in any other MMORPG can even be compared at all that, al other such games are blatantly inferior for PVP.
