Full body workout (splits) from home with minimal kit
11 Jun 2003
Sheffield, UK
Trying to work out a decent set of exercises to cover all muscle groups I can do from home on days when I can't get to the gym.
Needs to be doable with a basic weights bench, dumbells, exercise bands a chining bar and my own body weight. Intending this to be quite "accessible" so "Russian circus inverted standing incline kettlebell pikes" should have a bit of explanation
The splits i'm after look something like this so i'll keep to this layout and list under relevant days but it's obviously easy to change it up as wanted/needed:
Day1: 3 x Chest, 2 x Biceps, 2 x Abs
Day2: Rest
Day3: 4 x Legs, 2 x Shoulders
Day4: Rest
Day5: 2 x Back, 2 x Triceps, 1 x Traps, 2 x Abs
Day6: Rest
Day7: Rest
I'll post idea's I had and i'll update this a bit if others have useful input.
Day 1:
Chest: Dumbell Press (basically bench press with dumbells)
Chest: Push-ups
Chest: Reclined dumbell flys (lay on back, dumbell in each hand and make a cross, bring 'bells up and touch them above chest with arms straight)
Biceps: Standing dumbell curl
Biceps: Close grip pull ups (hands on pull-up/chinning bar about 2 inches gap between and pull up)
Abs: Crunches (not quite a sit up, just get your shoulders off the floor while laying down)
Abs: Leg raises (lay on back, straight legged, bring them up to verticle and back down)
Day 3:
Don't really have a good selection for home here. The gyms obviously much better for this.
Was thinking deep squats with the dumbells (lots) would cover quite a bit of the leg section but dumbells aren't the best for control.
Legs: Squats (weight at shoulder height, crouch down keeping bodyweight straight and weight in line with heel of feet, stand back up)
Legs: Dumbell lunges (?) (Take dumbell in each hand and almost go down to one knee and back up)
Legs: As above with a decent sized step (?)
Shoulders: Seated dumbell press (sit, dumbells at shoulder height and push above head, touch and back down)
Shoulders: Standing dumbell flys (dumbell in each hand resting on hips, raise arms till weight level with shoulders keeping arms straight then back down)
Day 5:
With the back it's rather tricky as a lot of these are "pull down" type exercises. The chinning bar is going to get overused here of course but otherwise...
Back: Wide grip pull-ups (hands very far apart on pull-up/chinning bar and pull up)
Back: Some form of pull down with the exercise bands. I think it will probably end up being seated using a door frame for an anchor point? Need help here.
Triceps: Probably get up and use the exercise bands again for a tricep pull down
Triceps: Skull crushers. (Take a heavy dumbell held in 2 hands, lay down on bench, extend arms above chest with dumbell, now lower it down towards the floor behind your head and back up.)
Traps: Dumbell shrugs. (HEAVY dumbell in each hand and shrug (like "I dunno" kind motion but slower and more controlled))
Traps: Inverted dumbell row (edge of table etc)
Abs: Crunches
Abs: Leg raises
Improvements please.
Would be nice to list a few more options under each.
Two exercises that you could use:
Inverted row on the edge of a table or something for your mid back.
Dumbbell lunges for legs.
But seriously, just go to the gym.
Completely agreed on "go to gym" but there's occasionally days when you really should go workout but really are stuck at home (waiting for a parcel for example) so looking for some stand in exercises that can be done at home.
If it's ever a "can't be arsed" day there's less excuse to not do an hour at home too :)
I'd got lunges on there already but the inverted row idea works indd.
Just want a bit of variety. Ended up stuck in yesterday and without the variety etc (and time spent setting up exercises) the repetition over an hour gets a bit dull.
Not after tonnes but just a few more ideas.
chins, hand stand pressups, dips, squats with someone on your shoulders. as basic as it gets.
get a piece of rope splice some eyes in it attach it to a tree or anything sturdy minimal kit required. be suprised how inventive you can be with nothing.
What equipment do you have?
Suggesting some kind of DB squat is going to be pretty useless if you only have 5kg to work with.
Db squat i'd thought of. It does kinda suck though and I don't have nearly enough weight for it. Squatting around 105kg (inc bar) at gym which would get kinda silly with dumbells.
I think a barbell is likely to be bought but then it's some kind of rack for squatting or having to go light/workout where I have some means of dumping the bar safely. I might just live with leg days being a bit hard to do from home.
This is kinda more where I was going. I find the idea of being able to get a decent workout when i'm forced to be away from gym/home quite appealing.
I think you missed my point. (btw the way you're doing DB squats isn't ideal, look up goblet squats)
What exact equipment do you have at home? There are loads of exercise options available, but for a lot of them you'd need the right amount of weight.
You mention: "Needs to be doable with a basic weights bench, dumbells, exercise bands a chining bar and my own body weight."
...but how heavy are your DBs, what resistance are your bands, etc.
body weight can be an amazing tool
how many here can do one handed chins ???
one footed deep, as in sit on your heal squats ???
one leg one hand pressup ??
crusifix ?
and so on
here go look at this guy !!! if you cant be bothered to look at it all 1.56 but i reccomend you watch the whole thing this is one of his best IMO
learn to use your body !
http://www.youtube.com/watch?v=5MeiwLLZjDo
lol the toning vs mass debate... its all the same thing taken to a diferent degree unless u get into muscle fibre make up fast and slow twitch t1 and t2 fibre response yawn......
