Big Bike Thread
Status
Not open for further replies.
Anyone got the link to that dude being "attacked" on that single track by the old guy for asking him to move so he can past? I cant find it, my youtube skills are lame :(
Sicker than gay monkeysex aids
Not really - same suspension system used on the new Undead and the cracktastic Revolt - the "Delta system"
Geo:
150mm fork gets you
Low setting:
66.5 HA/
13" BB/
SA 71.76 deg
High:
67.5 /
13.35" BB/
SA 72.80 deg
WANT so bad!
Yip. Fox seals suck. I was servicing my 36's every 6 months. Thats with me popping the seals out and cleaning everything every few months. The 2011 & 2012 forks don't seem to be so bad. IIRC the 2013 forks will be using new seals.
Can someone recommend a hybrid bike for under £500 that they have used and recommend.
It's for cycling to the station each day and although 90% of the journey is road, the remaining 10% is across a field when dry so it gets a bit bumpy.
The reason I've gone for MTB in the past, is I've found that the dual suspension helps my back. Last time i had a fixed frame, my back went within days.
It's this or scooter.
For those of you of a longer cycling history I found my old Minst Sauce jersey in my cupboard!
Wore it in to work for old times sake, must have got it when I was 14 I reckon. Then hid it away as it is very orange and not "trendy", I'm now old enough to see the humour and it still fits!
haha, i remember when i was younger the first thing i would do when i got a new MBUK was to look for the Mint Sauce cartoon :D
Had a wee keyring but missed out on the jeysey :(
Status
