That's the good part but haven't they been waiting for months?
Months is an understatement
Does anyone use a 9speed mech with a 10spd cassette?
The Boardman hybrid gets good reviews and is quite well spec'd for the money. Not ridden one myself tho.
haha, i remember when i was younger the first thing i would do when i got a new MBUK was to look for the Mint Sauce cartoon![]()
Had a wee keyring but missed out on the jeysey![]()
Looks all right. Could attract some attention to potential thieves though..
Couple of questions?
Why so many gears? I only ever use the top range on my current bike..
and why, as someone who knows nothing about bike tech, would this be faster than a MTB.
Thanks
You'll want a low ratio gear for going up hills and a high ratio gear for fast downhills. The more gear options you have between the high and low means you'll have more chance of finding something that perfectly matches your speed and desired pedal rpm.Why so many gears? I only ever use the top range on my current bike..
I need ShimanoNo, no one does... well maybe I lie - the people who aren't riding their bikes, because the gears don't work might do.
What do you need - I got a XX mech that I want to get rid of.
as I've already got the shifters and cassette.
XX is nice looking stuff though pricey.
i was a bit dubious to say the least.
(apart from the 2012/3 one thats £100!)Yip. Fox seals suck. I was servicing my 36's every 6 months. Thats with me popping the seals out and cleaning everything every few months. The 2011 & 2012 forks don't seem to be so bad. IIRC the 2013 forks will be using new seals.
Guys, some advice if you would be so kind.
I need to replace my scabby crank arms with something a bit nicer (and lighter)
They are bog standard Shimano cranks on a Shimano UN54 square taper BB.
Any recommendations on cranks for this setup? Getting some new pedals soon and have been wanting to replace them for a while (one to many rock strikes)
What touch said... Raceface cranks? ShimanoPerfect opertunity to upgrade to an outboard bearing bottom bracket.
Seen some excellent condition SLX cranks go for pennies.. (that I keep bloody missing!
Square taper BB has been rock solid for me over the years?Cheers both of you.. I'll pop to Halfords tomorrow and take a look and hopefully a trial.
As for scrotums wanting to nick it, get a decent chain too and take your seat and post off when you lock it for the day.
