Guild Wars 2
Nooo been logged in all day idle cause I have been with my boys, I noticed team chat wasnt working so logged out. Can't get back in now :(
I keep getting "you need to log in to use this"
Then you enter your email address and Password and click sign in (screen in box goes all pixelated) and fails to log in....??? jeez
Yep same problem here. I have raised as a bug and also emailed Arenanet support
Some bits are stupidly hard.
Almost everything seemed stupidly hard with the thief, I spent 20 minutes kiting a story mob one level higher than me with abow and arrow then finally after I had killed him I accidentally stepped out of the scripted area and it kicked me!
Yep it is too hard, every battle seems like it was designed for a group of at least 5 people on it, which is silly bc their will come a point when there won't be that player base there to assist and it just alienates people...but I'm guessing they plan to add bots in eventually
I'm playing it but don't really understand what I'm supposed to be doing haha. Just running around killing worm things coming out of the floor etc.. Safe to say I've never played Guild wars :P
Heh, just completed the level 19 personal story mission at level 15, Necromancers are OP.
The only death was the NPC companion :P
Was having a laugh running around the swamp killing Veteran Aatxes that spawn from destroying Underworld Portals, as a Necro they are pathetically easy to solo even a few levels below them and they drop some pretty nice stuff.
MH Axe - OH Dagger - Blood Fiend - Bone Fiend - Bone Minion. Criple, Weaken, Blind, Poison, spam skills and re-summon minions if they die, detonate minions asap. Worked on everything I've come up against so far.
Cant find where to repair my broken pants in Divinities Reach :(
Check the map for the little broken hearts, those are repair people.
Disliking the whole 50+ people around a mob and constant strobe effects and a boss you can't see use any animations to dodge 1 hit kill abilities and you can't see far out enough to see your damage or it's chat bubble for when it does use special abilities.
I'm refusing to play an Elementalist on principle, they feel like they have had about 10 times the effort put in to their design than all the other classes combined.
