What mid range card?
3 Apr 2007
South of the Watford Gap!
Currently have an Nvidia 460 in the PC and am looking to replace it, have around 180 to spend, have had a look around and have found the choice bewildering. My sons play the odd games on the system so am hoping to something with a bit more poke than the 460.
I've just been looking to get something like a GTX 560 Ti but only because 5 is greater than 4 :) Any help would be appreciated.
If you can get stretch to 185 then the 7850 on pre order now is probably your best bet. 1gb cards will probably start to struggle over the next year or so.
I too have a gtx 460 and sometimes think about buying a faster card for around that price but I don't think there is a card worth buying yet for £180 that's enough of an increase over the gtx 460. Just my opinion.
I'd say a 7850 like everyone else, but you HAVE to overclock it to get the performance out of it. If you get a goodun that'll overclock really hig,h then you're banging on the door of a HD 7950 so I've read.
