- 7 Feb 2008
- Surrey
Are there any advantages to shooting live action at 60fps? Because i can think of quite a few disadvantages...
Yup, see the previews of The Hobbit for said disadvantages.
As hard as it is to believe, most people, regular viewers and such - are detail blind. True story. Most people don't see obvious things, like wrong aspect ratios, low bandwidth issues and pixelisation of terrestrial digital channels let alone more "settle" problems like bad standards conversions, ghosting, dropouts etc which drive a lot of us literally nuts. Most of those people watch Freeview ITV pixelotto most of the day, and when they finally switch channels to a very average, rather badly converted Sky movie channel they think it's as good as it gets. And in all honesty, on a rerun channel, going through cheapest Sky box to a budget line, few years old korean laggy LCD set to incorrectly letterbox and stretch 16:9 content on a "HD ready" screen, it probably actually is. As good as it gets for them.
Well everyone seems to have a HDTV nowadays, I see the massive things on everyones walls driving past houses. If these people are still watching dvds then more fool them.
Yes theres a very noticeable difference if you have a 46"+ tv and don't sit 2miles away from your tv. It's all about size and viewing difference.
One hugely annoying thing with blu ray, they seem to have more junk than ever before you get to the main menu screen. Obviously this is down to the release studios and not the format itself.
I don't think Blu-rays will ever replace DVDs. by the time they get anywhere near there will be a new format.
They have completely replaced DVD's for me since PS3 came out, i haven't bought a DVD since, only blu-rays.
I'm confused as to why anybody with a HDTV(which is most people these days) would not use it to its full capabilities,
Regarding HDTVs, they are just the standard now. Flat screen = saving space. The majority of consumers don't look at spec or are even aware that the PQ is must better than their old CRT.
For some films, yes.
Bluray is a bit of a fad ... A dead format indeed but it won't stop me buying my fav films on it just for that extra detail, the rest are downloaded or streamed and I think that's the main reason that Bluray isn't really needed to 99% of most people
