The power connectors are mounted further towards the middle due to the short pcb, should make cable management a challenge.
would actually aid mine
spelling mistake in 1st picture
Dispalyport![]()
So this is a tiny bit better than a GTX580 then? For £290 its too expensive for that level of performance
It's fake, look at the 7, it extends too far over into the 0 space which is inconsistent with the rest of the type effect.[TW]Sponge;21820256 said:Not sure if serious.jpg
would actually aid mine![]()
I think id probably buy one for £290 ish, uses less power, will probably be cooler and quieter too
i dont get why would they place the PCI power connectors in the middle![]()
It may not be a tiny bit better - it may be a lot better!
Check out TT review! -> TT GTX 670 review
If this card will come out for around £280-300, it will be a total win against 680 and perfect swap for 580!
TBH I too think this'll be closer to the moneyI think its going to be 340 ish.
the pcb is a lot shorter
the rest of the card is the cooler...
This should bring a drop in 7950 prices..
