- 2 May 2012
Just got these monitors yesterday and love them, really great picture. I'm having an issue with a 3 way setup and posted the issue in the graphics card section but will add here too in case anyone can shed some light on this:
I have one MSI 7850 Frozr III and 3 x Samsung S23A700D in a 3 way setup @120Hz. I'm using catalyst drivers 12.3 (12.4 was even worse).
I have two monitors connected via startech mini display port active adapters and one monitor connected on the dual dvi. Unfortunately the dual dvi screen is tearing and it doesn't matter how I switch the cabling round, for the monitors, the monitor connected via dual dvi always does this. It's not unusable but it's one of those things, that you know it's there, even in windows and just gets annoying. After looking around I found other people having this issue and it seems to be the only solution is to have three connectors all the same type. This seems really odd though when most cards, even the 680s, have 2 of one type of connector and 1 of the other types.
Looking around at upgrades, some of the bespoke 7970's have 4 or more mini display ports but that means buying another active converter or maybe just going the whole hog for a 690 which has 3xdual dvi. Has anyone else had issues with this?
I think the gloss makes the monitor look lovely and new and luxurious, but yea, given the choice of a matt finish screen and passive 3D glasses, I'd have gone with that instead with hindsight. Fortunately though, no dodgy pixels on mine that I've noticed so far.
Better than I was expecting with my system. Skyrim looks damn impressive in 3D. I get 30fps with Tridef enabled, which is decently smooth and looks great. Load times are very slow though. Crysis warhead, again, very playable and looks good in 3D, though my framerate was anywhere between 18 and 25fps. Need for speed shift 2 worked in 3D, looked ok. Google Earth looks quite good. The 2D to 3D convertor is pretty **** after seeing these games with Tridef. Movies looked quite good, but I'd like to see a proper 3D movie.
