ClassicI guess at least if its varnished and you have a w/c leak it will just slide right off.
the best i could do in my break
i'm teasing you guys, you dont think for one minute that i'd paint my card do you,
the best i could do in my break![]()
yes.
it has to be Acylic gloss, it's the same stuff as they use to paint that Chinese GTX 680 thing, you know, it's the graphics card i found ages ago and posted up here a few weeks ago.
i'm teasing you guys, you dont think for one minute that i'd paint my card do you, i had all of this planed yesterday when i knew my ban was up
i was going to pretend that i had brought two 690s in SLI, but i thought no; that might annoy members too much, so i thought... ``do you remember that Chinese graphics card that came with a load of paints, like something out of Blue Peter ``
``i researched this card quite a lot, if it has bad coil whine you can cure it by painting the coils/ capacitors with gloss varnish, i used to do this for a living... you can easily varnish the whole card it doesn't halm it at all, just dont get it into the sockets etc or on the GPU.
you can spill it onto the rear face of the card, let it run around the rear area and then let it drain off, just dont use the card for a day, let it dry out totally, this will cure the whine.``
ha ha
it's a classic
You just lost all remaining creadibility.
No way I am buying you was joking. You have realised what you have said and tried to back track.
I am 100% sure you would do this kind of thing.
