Well i got the !!!!
Status
Not open for further replies.
the best i could do in my break :p
Classic :D I guess at least if its varnished and you have a w/c leak it will just slide right off.
it has to be Acylic gloss, it's the same stuff as they use to paint that Chinese GTX 680 thing, you know, it's the graphics card i found ages ago and posted up here a few weeks ago. :D
http://www.google.co.uk/imgres?q=ch...dsp=25&ved=1t:429,r:1,s:21,i:121&tx=105&ty=58
i'm teasing you guys, you dont think for one minute that i'd paint my card do you, i had all of this planed yesterday when i knew my ban was up
i was going to pretend that i had brought two 690s in SLI, but i thought no; that might annoy members too much, so i thought... ``do you remember that Chinese graphics card that came with a load of paints, like something out of Blue Peter ``
I am 100% sure you would do this kind of thing.
``i researched this card quite a lot, if it has bad coil whine you can cure it by painting the coils/ capacitors with gloss varnish, i used to do this for a living... you can easily varnish the whole card it doesn't halm it at all, just dont get it into the sockets etc or on the GPU.
you can spill it onto the rear face of the card, let it run around the rear area and then let it drain off, just dont use the card for a day, let it dry out totally, this will cure the whine.``
ha ha
it's a classic
ha ha
it's a classic
No way I am buying you was joking. You have realised what you have said and tried to back track.
no i'm teasing you.... but i have painted the roof of my PC Case you'll see it in a few days time, i painted it 10 times, i spent 50 quid on car paint..
i painted it:-
light grey
dark grey
yellow
brown
bark yellow
light yellow
gold
red
black
yellow
i brought Megahalems, then Thor's hammer, then Xigmatek Aegir, i have also brought about 30 fans and thrown the lot away.... am i teasing you or telling the truth ;)
Status
