Dom's Training Log
They they felt great today. It's weird but my stance used to be much narrower but since starting lifting heavy again I've had to go much wider and found that I get a lot more power out of it. Weird.
Really nice form Dom looking nice on the pause reps there.
On the stance width/power comment, isn't power only reduced when your brining your legs/knees inside your feet? From the looks of your lifts your legs are nicely over the centre of your feet so no reason you should lose any power there.
What's your record target?
Nope, it depends on a lot of things. For example, overall flexibility in those ranges, cross sectional area of muscle involved, elasticity of tissue in the relevant position, etc.
I'm not losing any power, I'm saying I'm more powerful.
The british record 192.5kg so that is the goal for this year :).
Deadlift
5x60kg
3x100kg
3x120kg
6x2x140kg
Pullups
3x8xBW
SALM Press
10x10kg
3x8x20kg
Face Pulls
10x80lbs
3x15x100lbs
30 Degree Raise
3x10x15lbs
Pallof Press
2x8xhorizontal and vertical
8xhorizontal only
Did a load of other core stuff today. Gonna hurt tomorrow :D.
It means he's growing Type IIX man fibres rather than pussy Type Is
That any clearer :p
Also, I post setxrep structures like that all the time, someone isn't paying attention ;)
That any clearer :p
In other words no different than standard hypertrophy training?
Yes, but typically hypertrophy rep ranges are 8-12 reps with short rests which targets metabolic factors. This induces faster growth, but not of the type IIX fibres.
It's not really something you need to worry about.
Not worrying, just curious as to why he was doing those rep/set ranges as it seemed odd :) I'm greedy really....I just want to learn everything in life
I would have presumed it was for strength, but I'm guessing due to the extra sets it's hitting on the verge of hypertrophy but not in a standard-hypertrophy way? Or whatever the word is for 'the pump' :p
No :p
It is hypertrophy, just not stimulated by metabolic factors.
"The pump" is an entirely separate concept, but it is often associated with higher rep ranges.
No :p
Okie doke :) Still not entirely there, hopefully I'll find something to read up on it a bit more later
It's very advanced and isn't likely to affect your training (which is what I meant when I said "don't worry about it"). Your time would be better spent researching and practising other things.
edit: sorry if that sounds patronising, it really isn't meant to be. This kind of stuff is only really worth knowing at high levels of strength and conditioning coaching.
No that's fine :) But then that's why I would like to understand it I guess, so when I get to that point, I won't be at a loss for what to do.
ANYWAY! Kinda hijacking Doms log here (Sorry chap :p)
