**OcUK GTX 670 IN STOCK & REVIEW PLUS AN EPIC PYRAMID/CASTLE HYBRID!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Stock Palit GTX 670 (Boost 1071MHz) - Heaven 2.50 @ 1920x1080 4x/4x with tesselation on normal - Max Temperature - 57c (Fan 85%)
Stock GTX 680 (Boost 1071MHz) - Heaven 2.50 @ 1920x1080 4x/4x with tesselation on normal - Max Temperature - 52c (Fan 85%)
Palit GTX 670 1215MHz / 7000Mhz - Heaven 2.50 @ 1920x1080 4x/4x with tesselation on normal - Max Temperature - 68c (Fan 85%)
Palit GTX 670 1215MHz / 7000Mhz - Heaven 2.50 @ 1680x1050 4x/4x with tesselation on normal - Max Temperature - 68c (Fan 85%)
Palit GTX 670 1215MHz / 7000Mhz - Heaven 3.00 @ 1920x1080 4x/4x with tesselation on normal - Max Temperature - 78c (Fan AUTO)
EVGA GTX 680 SC 1266MHz / 6800Mhz - Heaven 2.50 @ 1920x1080 4x/4x with tesselation on normal - Max Temperature - 56c (Fan 85%)
EVGA GTX 680 SC 1266MHz / 6800Mhz - Heaven 2.50 @ 1680x1050 4x/4x with tesselation on normal - Max Temperature - 56c (Fan 85%)
EVGA GTX 680 SC 1266MHz / 6800Mhz - Heaven 3.00 @ 1920x1080 4x/4x with tesselation on normal - Max Temperature - 56c (Fan 85%)
Hi there
Just to add to the original part of the review, here are the results in Heaven 3.0 from a Gigabyte GTX 670 WindForce 3X I tested.
Clock speeds were:-
1337MHz Core Boost Speed
7200MHz Memory Speed
The above was only benchmark stable, for 24/7 game running I'd settle for around 1250MHz/6600MHz. :)
Heaven 3.0 @ 1920x1080 4x/4x with tesselation on normal - Max Temperature 52c (Fan 100%)
Heaven 3.0 @ 1680x1050 4x/4x with tesselation on normal - Max Temperature 52c (Fan 100%)
In short these WindForce 3X cards due to the rather impressive overclocks they can hit, outperform a stock GTX 680 when running at approx 1150MHz / 6200MHz speeds. When the cards are pushed beyond 1200MHz core they outperform a GTX 680 and in short I've not yet found a GTX 670 which can't hit 1200MHz core, so on the overclocking side they are doing very well. Off course you can also clock a GTX 680, but the facts are a GTX 670 is approx £100 less than a GTX 680, yet the performance difference at best is only 10%, your certainly saving a lot more than 10% in cash. :)
Conclusion
In short the average performance difference in benchmarks and gaming is under 10% between the GTX 670 and GTX 680. For some strange reason our Palit GTX 670 was boosting too 1071MHz, yet according to the specification it should only boost too 980MHz. This I can only assume is due to NVIDIA's boost technology detecting the card can run much higher boost speed without issue, hence the high boost clock speeds we witnessed from the stock Palit card. But saying that the Gigabyte WindForce 3X was boosting as high as 1202MHz by itself. As such when the GTX 670 boost so high compared to a stock GTX 670 the actual performance difference is closer to 5%.
In short 1150MHz core speed on a GTX 670 gives stock GTX 680 performance levels and they all seem to manage such speeds easily. When up against a good clock GTX 680 such as the EVGA Superclock the GTX 680 just manages to keep its lead over the amazing Gigabyte GTX 670 WindForce 3X card, but it is marginal at best and the price difference is close to £150.00
In short a GTX 670 is approx £100 cheaper than a GTX 680 and with a mild overclock will give you GTX 680 performance, which is an overclock all GTX 670's seem to do without breaking a sweat. In short if your only interst is gaming, then right now I have to say the GTX 670 is simply the gamers card of choice, it has all the features of GTX 680 and performs within 10% of it for far less money and with an overclock can outperform a stock GTX 680. As such I'd take the GTX 670 everytime! The only reason to go for the GTX 680 is if you do crave the absolute best or are chasing benchmark numbers, but apart from that the GTX 670 just seems the obvious choice.
If it was my money, then I'd be buying either a Gigabyte GTX 670 WindForce 3X or a KFA2 GTX 670 EX OC, those are the two best cards for low noise and overclock without a doubt. :)
To make your buying decision easier, here are the models which all under each PCB type:-
Short PCB - NVIDIA Reference design - Approx 1250MHz max aircooled core clock
Palit / Gainward (including Jetstream & Phantom)
EVGA including Superclock (Seem to be best overclocking reference design cards)
KFA2 Reference
MSI OC
OcUK
Long PCB With 8+6 pin power - GTX 680 PCB Design - Approx 1400MHz max aircooled core clock
Asus GTX 670 DirectCU2 (2x 6pin power, does not clock as well as the 8+6 power cards)
Gigabyte GTX 670 WindForce 3X (8+6pin power)
KFA2 GTX 670 EX OC (8+6pin power)
Hi there
So buy yourself a GTX 670 today from our extensive range with nearly all models in stock:-
Asus GeForce GTX 670 DirectCU II 2048MB GDDR5 PCI-Express Graphics Card @ £371.99 inc VAT
The new Asus GTX670-DC-2GD5 with Digi+ VRM for the ultimate power control and enhanced Overclocking comes with the Asus exclusive DirectCU II for up to 20% better cooling.
The GeForce GTX 670 graphics card taps into the powerful new GeForce architecture to redefine smooth, seamless, lifelike gaming. It's more than state-of-the-art technology and features. It's truly game-changing performance.
Faster:
- Innovative new GeForce architecture-designed to deliver faster, more power-efficient performance
- NVIDIA GPU Boost technology that dynamically maximizes clock speeds to push performance to new levels and bring out the best in every game
- The power to turn on lightning-fast antialiasing in a huge variety of games, automatically, with NVIDIA FXAA
- Support for new temporal antialiasing (TXAA) technique that delivers the ultimate combination of image quality and performance.
- The power of 3-way NVIDIA SLI® technology
Smoother:
- Ultra-smooth gaming experience with exciting new NVIDIA technology advancements
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
Richer:
- NVIDIA® Surround™ multi-monitor gaming on a single GPU (three gaming monitors plus one accessory display)
- Supercharged NVIDIA PhysX® and NVIDIA 3D Vision® performance
Specification:-
- 20% cooler and Vastly quieter performance with ASUS exclusive DirectCU II thermal solution
- ASUS DIGI+ VRM technology with 6+2 phase Super Alloy Power for precise digital delivery and enhanced overclocked headroom. (compared to 4+2 phase in reference card)
- GPU Tweak utility allows you to tune graphics card performance and check card status via an intuitive interface
- Full length PCB, better for overclocking
- Core Clock: 915MHz (GK104)
- Core Boost Clock: 980MHz
- Memory: 2048MB GDDR5
- Memory Clock: 6008MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1344
- Shader Clock: 1960MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 170 watts at stock speed)
- 1x 8-Pin & 1x 6-Pin PCI-E Connectors required
- Card Dimensions: 270*111.15*38.75 mm
- Warranty: 3 Years
Only £371.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 670 2048MB GDDR5 PCI-Express Graphics Card (02G-P4-2670-KR) @ £339.95 inc VAT
Faster:
Smoother:
Richer:
Specification:-
- Shader Clock: 1830MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- 2x 6-Pin PCI-E Connectors required
- Warranty: 3 Years
Only £339.95 inc VAT.
ORDER NOW
EVGA GeForce GTX 670 Superclock 2048MB GDDR5 PCI-Express Graphics Card (02G-P4-2672-KR) @ £353.99 inc VAT
Faster:
Smoother:
Richer:
Specification:-
- Core Clock: 967MHz (GK104)
- Core Boost Clock: 1046MHz
- Memory Clock: 6210MHz (Effective)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
Only £353.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 670 2048MB GDDR5 PCI-Express Graphics Card @ £329.95 inc VAT
Faster:
Smoother:
Richer:
Specification:-
- Core Clock: 965MHz (GK104)
- Core Boost Clock: 1045MHz
- Shader Clock: 1930MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Only £329.95 inc VAT.
ORDER NOW
Gainward GeForce GTX 670 Phantom 2048MB GDDR5 PCI-Express Graphics Card @ £371.99 inc VAT
Faster:
Smoother:
Richer:
Specification:-
- Phantom II Cooler for quieter and superior cooling
- Core Clock: 1006MHz (GK104)
- Core Boost Clock: 1084MHz
- Memory Clock: 6108MHz (Effective)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
ORDER NOW
Gigabyte GeForce GTX 670 Windforce 3X 2048MB GDDR5 PCI-Express Graphics Card @ £365.99 inc VAT
Faster:
Smoother:
Richer:
Specification:-
- Innovative WindForce 3X Cooling solution for lower noise and lower temperatures
- Core Clock: 980MHz (GK104)
- Core Boost Clock: 1058MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
Only £365.99 inc VAT.
ORDER NOW
KFA2 GeForce GTX 670 2048MB GDDR5 PCI-Express Graphics Card @ £325.99 inc VAT
Faster:
Smoother:
Richer:
Specification:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Only £325.99 inc VAT.
ORDER NOW
KFA2 GeForce GTX 670 EX OC 2048MB GDDR5 PCI-Express Graphics Card @ £359.99 inc VAT
Faster:
Smoother:
Richer:
Specification:-
- Innovative cooling solution for lower noise and lower temperatures
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Only £359.99 inc VAT.
ORDER NOW
MSI GeForce GTX 670 OC 2048MB GDDR5 PCI-Express Graphics Card (N670GTX-PM2D2GD5/OC) @ £329.95 inc VAT
Faster:
Smoother:
Richer:
Specification:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
ORDER NOW
OcUK GeForce GTX 670 2048MB GDDR5 PCI-Express Graphics Card @ £319.99 inc VAT
Faster:
Smoother:
Richer:
Specification:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Only £319.99 inc VAT.
ORDER NOW
Palit GeForce GTX 670 Jetstream 2048MB GDDR5 PCI-Express Graphics Card @ £359.99 inc VAT
Faster:
Smoother:
Richer:
Specification:-
- Jetstream Cooler for quieter and superior cooling
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
ORDER NOW
EVGA GeForce GTX 670 4096MB GDDR5 PCI-Express Graphics Card (02G-P4-2671-KR) @ £399.95 inc VAT
Faster:
Smoother:
Richer:
Specification:-
- Memory: 4096MB GDDR5
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
Only £399.95 inc VAT.
ORDER NOW
EVGA GeForce GTX 670 Superclock 4096MB GDDR5 PCI-Express Graphics Card (02G-P4-2673-KR) @ £419.99 inc VAT
Faster:
Smoother:
Richer:
Specification:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
Only £419.99 inc VAT.
ORDER NOW
Hi there
Off course the main show, the OcUK epic pyramid/castle hybrid. :D :D :D :D :D
So if anyone doubted we have stock, now all that doubt is removed, in total we have over 1000 units in stock which is a major chunk of the actual worlds allocation. :D :D :D :D
GTX 670 launch system - Ultima Demon Hunter
Check our sweet GTX 670 launch system out, Diablo 3 is packaged for FREE also :)
"Ultima Demon Hunter" Intel Core i7 4.50GHz Diablo 3 Quad Core System @ £1398.99 inc VAT
**FREE DIABLO III FULL PC GAME - LIMITED TIME ONLY**
For the first 50 sales across the range of the Diablo 3 limited edition gaming systems we are offering a FREE full retail copy of Diablo 3 so you can get straight into the action. terms & conditions apply.
Prowl the Sactuary and hone your skills with the "Ultima Demon Hunter" Limited Edition Diablo 3 system. Designed and engineered by our in house technicans for optimal gameplay for Diablo 3. With the latest Intel Core i7 3770K CPU overclocked to 4.50GHz, utilising quad core technology to their push the limits of truly frightening performance. Featuring the awesome Nvidia GeForce GTX 670 2048MB Graphics card. Push back the hordes of undead and fight 'till the death! With the "Ultima Demon Hunter"!
Why You Should Buy This System
- Featuring the Nvidia GeForce GTX 670 2048MB Graphics card
- Precision built and cabled by Overclockers UK expert technicians
- 8 Hours stressed tested and quality controlled
- Optimised for intense combat and Diablo 3 gameplay mechanics
- All systems with an operating system selected ship out with a pre-installed 180 day trial of Panda Antivirus 2012
System Specification
- Case: NZXT Phantom Enthusiast USB3.0 Full Tower Case - Red
- Power Supply: OCZ ZS 750w PSU
- CPU: Intel Core i7 3770K 3.40GHz @ 4.50GHz Quad Core CPU
- Motherboard: Gigabyte Z77X-UD5H (Socket 1155) DDR3 Motherboard
- Cooler: Prolimatech Genesis CPU Cooler w/x3 Sharkoon Silent Eagle 120mm Fans
- RAM: 16GB DDR3 1600MHz Dual Channel Kit
- Hard Drive: 1TB HDD
- Graphics Card: Nvidia GeForce GTX 670 2048MB Graphics Card
- Sound: Asus DG 5.1 Sound Card
- Optical Drive: LG DVD+/-RW SATA Drive
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
Utilising the latest hardware, the "Ultima Demon Hunter" is the starting point for the perfect Diablo 3 gaming machine.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
* No OS systems are fully tested with the same extensive methods as systems chosen with an operating system. Including tests such as CPU, memory and GFX stress tests. All no OS systems are formatted completely before shipping.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
* T&C's Free game is subject to availibility and limited to the first 50 sales across the range of the Diablo 3 gaming systems. This offer may be withdraw / removed or amended without prior notice. Orders made before release date of the game will be backordered and shipped on release of the game.
Only £1398.99 inc VAT.
ORDER NOW
Hi there
OK guys, these are now live, check out our review and you will see if you want to overclock and want the quietest cards then Gigabyte WindForce 3X amd KFA2 EX OC versions are the best.
Otherwise get a reference card from MSI or KFA2 as they have great warranty and service. :)
GET YOUR WALLETS OUT! :D :D :D :D :D
£320 and in stock, nice job guys
AMD will $*** themselves now, the 670 is a no brainer compared to 7970
Anand:
Depending on the game and resolution we’re looking at the GTX 670 reaches anywhere between 80% and 120% of the 7970’s performance. AMD sails by the GTX 670 in Crysis and to a lesser extent Metro, only for the GTX 670 to shoot ahead in BF3 and Portal 2 (w/SSAA). Officially NVIDIA’s positioning on the GTX 670 is that it’s to go against the 7950 and not the 7970, and that’s a wise move on NVIDIA’s behalf; but the GTX 670 is surely nipping at the 7970’s heels.
I'm expecting price cuts for both 7950 and 7970.
680 will also get a severe cut once they can meet demand.
Not so sure about AMD, they may just accept defeat, but they still sell at the new prices.
680 won't happen as right now still massive shortage until probably July at this rate.
EPIC PYRAMID IS EPIC
if I order a 570, could you 'accidentally' stick one of these in the box for me instead :p No one else will ever have to know :p
Amazingly the 670 is actually faster, just, than a 680 in some titles at some res. This isn;t in anyway common but you do see it in the Anand review.
The reason being both cards have the same rops so without the eighth SMX to power the card can overclock itself higher and in ROP limited games, not shader limited, it can beat a 680.
Great price on these OCUK but I can't help but feel sorry for the guys who have only just paid a £100 more for the GTX 680. Surely with this card being so close and in some cases matching the 680 it's a bit unfair to undercut there own product by such a margin so soon. I have sold on my gtx 680 now but I would be a bit ****ed off at them to be honest.
