- 19 Oct 2002
- Shakespeare’s County
Proof please, as the teams I have worked with always used the sponsors normal products.
is that because its free?
Simon, I am aware you have worked blending oils for various companies, (at least I think it was you that claimed this in another oil thread) so rather than patronise and try to argue semantics, why don't you just tell us all of the problems you know of with these lessor oils.
Partly, the other part being it would be an embarrassment (to the sponsor) to be seen using anything else. As good as saying "we'll take the money but their products are carp".
These cheaper oils you mention already have achieved and exceeded the ratings required by car manufacturers, the only reason they recommend specific brands in some handbooks is the subsidies they get on the oil they use for initial filling and testing.
Patronise?
I work for ONE company and do a bit more than blending thanks. How about you stop posting about something you appear to know very little about and leave it to experts to get on with it.
I don't become an expert in a subject to then plaster my knowledge on internet forums. For a start most of it is confidential.
My issue is you have made blanket statements that are incorrect, and when challenged you accuse me of being patronising. I know of many problems, I know of many fixes, I know of many OEM hardware issues - I won't share them on here though.
I don't see that many cheaper oils with MB229.51 or VW 504 507
Fair point, but is that because they wouldn't meet those specs or because they didn't have them tested?
My brothers BSB team was sponsored by Pirelli, but their race tyres were so shocking they ditched them and paid for Dunlops. I could explain here why they were bad, but it is irrelevant![]()
Well forgive me for no knowing the full involvement of your work.
Ok, so how about some specifics about stuff I know little about and are incorrect?
I don't wanna know what you cannot disclose, and I care not a jot about it.
the facts I have stated are as follows...
1. Bearings make no metal to metal contact under normal operating conditions (I don't class startup as normal operating conditions which they do make some metal to metal contact).
Easy to rationalise that choice with laptime data though!
Even easier when the you keep high siding or having the front tuck under you![]()
Well it is, there is contact, and lots of people class it as somthing that occurs in the normal operating envelope of an engine.
Which kind of makes your 'fact' 1 nothing more than your opinion.
Everyones butt dyno is different
Like I said, objective data = rational decision.
2. Even though this contact occurs, it is minimal and is quickly removed by a good fully functional lubrication system and that oils that meet the manufacturers specifications will be fine, including Halfords.
3. Mixing oils of the same type and grade ie full synth 10w-40 will not cause any issues as long as that oil still meets the same manufacturers standards.
