Hi there
They have arrived! All orders shipping!![]()
Coming from a 5750 should be good considering I bought one of the Korean 2560*1440 monitors
Use my bench as a template, saves you the hassle going through Heaven 30 + times. You should be able to get more or less the same overclock.
http://forums.overclockers.co.uk/showpost.php?p=21875408&postcount=1012
Waiting for the drivers to download, anyone else think the card looks and feels a little cheap ?
MW
Can't say I'm blown away by the fan shroud, but it is reassuringly weighty for the size. I will admit though that I am confused why the box says four heat pipes when there are only 2.![]()
