How should i set up my HDDs
17 Mar 2012
Im about to format all my HDDs i have laying around and if possible put them in a raid set up but not sure if i can, if i can whats the best one for me.
im looking for speed mostly, i dont really have any SUPER important just games and music that i could live with out so i dont need the back up.
i have:
500gb
120gb
250gb x 2
Thanks James
Raid sets should be of identical drives, preferably of the same size.
if those drives are the same make and you raid them together you would get a raid set of the smallest drive ie 120gb
tbh dont bother with raid nowdays i used to but not anymore its more pain than its worth i think.
especially if your an addicted upgrader
Don;t know where you're getting the "pain" from. Been running raid 0 for year on my OS disk for years without trouble.
You said you have:
500gb
120gb
250gb x 2
The biggest performance increase that I've seen was when going from 1 to 2 disks in Raid 0. Beyond that, the increases were not as noticeable - probably measurable, but certainly not significant enough for you to feel the difference.
I'd be tempted to ignore the 120GB drive and use that as a backup, and use the 2x250gb in Raid 0 for the OS and 500gb for local storage/backup. You could include the 500Gb drive in the array, but as I already said, I don't think you'll be able to discern the benefit.
If you also consider that usually the smaller drives are older, and so the older drives usually have a higher latency, negativing part off the benefit "upgrading" the array
If you just want speed, then 4 drives in Raid 0 or Raid 5 would give you a capacity of 120gb, wasting a total of 130+130+380=640gb, but as said previously I can;t be sure how much quicker that will actually really be.
i was but being the type who swaps out mobo and cpu and drives a lot resetting raid each time and taking the raid to a new system each time i find it easier to not bother with it now especially with ssd
All true enough - you need to reinstall the OS with any change of motherboard. I've not had to for any other component changes, including the CPU. Switched my 2600k for a 2500k and then back again without problem. Also recently switched the i7 950 out for an i7 920, and then back again without any hiccups.
in fact I used my twin 300gb raptors on my RIIE board, then when I moved them over to my P8Z68-Pro, they were recognized as an array there too! The only ones that haven't registered for me have been when I have used an array and migrated controller manufacturer - specifically Highpoint to Intel and Vice-verso.
I say "All true enough - you need to reinstall the OS with any change of motherboard." but what I mean is that you spend less time fixing things if you re-install from scratch IMHO, plus end up with a clean system, which I've always found more responsive than an old one that's moved.
just my pennies worth :)
depends tbh on the chip set, but i found with multiple operating systems then a raid array also it was getting to much to install it all as i wanted so now i dont bother with raid anymore
ssd has made that decision easier i guess but running diferent arrays for diferent things then thinking oh im gonna change my mobo and het this drive or this cpu and try that all the installing and reinstaling was a pain
raids are harder to migrate.
