- 10 Apr 2012
- Jersey
not to RMA no, but DSR you don't get the cost of return postage back so you lose £10 in doing so
apologies for highjacking but what's the difference?
Really with the brown tape on the actual box? Pics of that?
Can post something tonight. Bit annoying but nothing major.
I've peeled most off but if i try on the stickers it pulls them to bits.![]()
Why would there be brown tape on the box though?
MMh, there was brown tape right over what I presume to be the serial number sticker on mine too. Couldn't read through it, and taking it off ripped off the top right corner of it. What is the important bit, i.e. what format is the serial itself in so I can check that is not damaged.
Someone wrapped the box in bubble wrap except the ends.
They then ran brown wrapping tape around the bubble wrap side to side and end to end. The end to end bit went around the ends of the box and stuck to them as they were not covered by bubble wrap.
I successfully peeled the tape off one end as it had no stickers. Phew!
When i tried the other end as soon as i hit the serial number sticker the brown tape rips the sticker off with it.
So i now have a serial number sticker which you can read but only through the brown tape. Minor thing but annoying none the less.![]()
Good afternoon,
Glad you have received your order, I shall pass the details on to the warehouse manager.![]()
Am I the only one who doesn't really "get" this card? I mean, nVidia have basically killed the market for the GTX680. I don't regret mine but if I was buying now, it'd be one of these, all day, every day.
It's a very strange move IMO. They'd have been better putting this between the 7970 and 50 and pricing it to suit.
Well mine just arrived, and guess what? Brown packing tape slapped right around the box and right over the serial number white lables. Shoddy work. How do you stand if you want to return it under DSR?
is it worth you sending it back at your cost for tape on the box.....Don't worry mine arrived the same, it peels off the serial number label fine, just peel it back really slow.Boge said:Well mine just arrived, and guess what? Brown packing tape slapped right around the box and right over the serial number white lables. Shoddy work. How do you stand if you want to return it under DSR?
