Actually with a bit of care I just managed to get the tape off the paper lables without causing too much damage. A couple of corners lost but the info is still all there. Right. I'm off to mess around.............
(as a side note if you compare the 480 and 680 performance at 2560x1600 then it shows a 52% speed increase over 2 generations which doesn't sound like all that much but then 400->500 series wasn't really a massive change.)
A generation change is only when the die shrink occurs for me so 8800->280->480->680
I did a comparison before but basically 480->680 is the worst gain in recent times, even 280->480 was better
i dont think they have
remember the 680 is massively overpriced due to demand
the real price should be 380-400 not the 460+ it is currently
the price of the 670 will probably be around 300-320 and im sure there will be loads of people happy to pay an extra ~£80 for a 680 over a 670
Spot on. The fact that the Gigabyte was originally at £315 elsewhere tells you what these should have been priced at.
Should I go from a GTX 480 to a GTX 670? It bothers me how hot it runs and i'd like BF3 to be a bit more stable. And in laymans terms whats the differences between small pcb anf lon pcb cards?
The longer pcb is the same pcb that manufacturer uses for their 680.
it *may* give you you better overclocking results. It seems on average to swing that way so far. Maybe the 670 reference pcb has a lower voltage limit? Can't say without someone taking it to bits and examining the power delivery.
I'm not so sure, there seems to be a spread of low clocking long cards and a few high clocking small cards, there doesn't seem really to be a firm pattern one way or the other
As with any overclocking it's a silicon lottery.
If the voltage is the same there's probably little difference tbf.
If I was getting one I'd go for the long pcb version just so I don't have cables all over the place
Not sure thats quite right in my experience. Keeping the chip cooler can help with overclocking even at the same voltage. Heat is one of the factors that prevents a chip running at a given speed. For example my 480 was only a fair overclocker with the referance cooler, but as soon as i slapped a Zalman on it and cooled it right down for the same stock voltage it would clock a lot higher.
Thus for the same stock voltage and the same quality GPU (non binned) should clock higher on a non-referance card if the enhanced cooler does indeed work.
If you get a binned chip with the more expensive non-referance cards then the difference will be even more.
