Gbt 7950 283£.Is it worth it now when gtx 670 is out?
10 May 2012
How far can I OC this gpu for stable everday use?I know that card got plenty room for OC.How gbt hd 7950 perform after OC,when you compare it to gtx 670?
*No discussion of competitor pricing!*
What model is the 7950? is at a non reference one with a good cooler?
Why not just try the 7950 for a couple of days, you can always return it under DSR. If you can get an overclock in the 1200MHz region it will perform very similarly to a 670.
Early indications are that if you can get the 7950 to 1200/1600 it will outrun a 670 at 1300.
We need more data.
DSR is not an option in that case.
I've cancel the order.I'm going to postpone build of my rig for few weeks now.Price of 79xx should go down and we'll have more date on gtx 670 performance i OC.
cheers for help
