Have you had your teeth whitened?
I get my teeth cleaned and polished with noisy tools every time I got to the dentist, but he's my brother so all treatments are free \o/
Yep, got a dye kit from the dentist, had to get a mould made for my teeth, cost £300 in total, it does make a difference. When this bleach stuff runs out, I'm gona look into the Crest Strips everyone keeps mentioning
Pointless post of the year goes to...
*drumroll*
There was a question, I answered it :p
If you must know, no, but I've never felt the need to, I've used the whitening toothpaste occasionally, but since people tell me it's had no effect it's probably a placebo more than anything else...
kd
Same for me, smashed my front top 2 and now the rebuilt part hasn't coloured the same as the original parts of teeth that's left. So looking at whitening to make them match
If they rebuilt it then they match it to the colour your tooth is at the time and it stays that colour. These kits will not do anything to it and likely make it look worse as they will work on the real tooth. I'm sure the forum dentist guy will be on soon and maybe he'll explain it better.
Edit: I read it again and I think I misunderstood. The bit you had repaired is lighter not darker right?
Yeah new bit is lighter
The woman that does mine is a cow.
She calls me by my first name and refers to herself as Mrs Whateveritis. Then she proceeds to hurt me. I let the name thing go the first time it happened, and now it's too late to be indignant about it. Add to that I'm older than her, better paid, better qualified and better educated I don't feel I should be getting my first name and her by surname.
Does it hurt when your brother does it? Or does my nasty witch of a hygienist hurt me on purpose?
The hygenist we have had for years has recently left.
For years we have had to suffer a lot of pain, bleeding and a thoroughly unpleasant experience from getting a clean and descale.
I was thoroughly shocked by the new lady, absolutely - no - pain - whatsoever. I cannot believe the difference.
You have a nasty witch of a hygenist.
It's fine if you get the proper retainers made and they mould around your teeth. Only thing you can get is a little tooth sensitivity, it won't burn your mouth.
Cool I''' look into the kit that was recommended on the last page. When I get a scale and polish done at the dentist that isn't the same as getting your teeth lightened. Teeth whitening costs something like £200 iirc.
that price is pretty much for the custom retainers. They are expensive.
when I get a scale and polish my gums bleed and it hurts a bit, but the dentist says that is normal. :confused:
