To turn eyefinity on/off presets are the way forward, to add them just set it up how you want and in CCC for Presets -> Add Preset... then enter the name and hotkey you want. I've got 3 setup:
Ctrl+Shift+1 = 'Normal' which is the windows taskbar on the left screen, and the others extended
Ctrl+Shift+2 = Is just normal extended again but with the windows main screen as the centre for non-eyefinity games
Ctrl+Shift+3 = Eyefinity
Really doesn't take long to switch, my only downside is that Pidgin has a habit of crashing when the presets are switched but that's just dodgy software![]()
OMG OMG Finally no longer a rookie![]()
took me long enough mind you,, especially when you get races like that last one where one guy just spend the whole race armming people that went near him![]()
I'll take it easy at the start but in that situation I would've at least considered it, the gap was there, you were relatively slow, definite chance right there...
Although he came from far back you should've been able to see him and act accordingly imo, this is one of those times where the incident isn't really your fault (I stick by my 'racing incident' verdict) but you could have avoided the incident (and in this instance kept your place)
Think I am going to bite the bullet and get this sorted out tomorrow. I am simply having too much fun with this relatively obsolete version. How long would it take to get into racing the mighty FW31?
