ok, was that a question?
Overclocks aren't guaranteed either...
Yes it will be similar. I don't think the asus directcu and windforce are worth their current prices though.
what just wondering if i could get a similar proformance from the 670 as the 680
You could potentially oc a 670 to compare with a stock 680 but then you could oc a 680 and make that even better so it's just depends what you wanna pay
or would anyone like to predict a trend for increasing tech prices in future? maybe the 770 will be £400?
Just for fun, did some quick googling.
seems the 470 was 299 on release, same as the 570.
why is the 670 now 360 ish?
are we just getting milked this gen?or would anyone like to predict a trend for increasing tech prices in future? maybe the 770 will be £400?
ah yes I forgot that in a recession everything gets more expensive (which seems backwards when you think about it).
not sure why you think nV is increasing its customer base with more expensive products, however.
The KFA2 EX OC already gives GTX 680 stock performance out of the box, overclock the 680 and it performs better. But the gigabyte is a much better card.
But a GTX 670 clocked 100 MHz higher than a 680 performs the same.
