Prob going to download this tonight, anyone have any experience with running a similar spec to mine? Reckon I'll be able to get 120hz/fps running constant at max without SLI?
Easily.
I've got a single 590 and it's hardly breaking a sweat running D3 with everything maxed out so I think you'll be fine.Prob going to download this tonight, anyone have any experience with running a similar spec to mine? Reckon I'll be able to get 120hz/fps running constant at max without SLI?
Is that not a little bit arrogant? He was making a observation based on an opinion. Not insulting your game skill.![]()
Ah, yea, worded my original question terribly.
So, say I had a 10.0 damage ritual dagger, I would be 14 damage with my poison dart? Then plus 25 int, I will be doing a total 39 damage?
I don't suppose it matters which server I'm on for this character if I'm going to play through on solo does it?
You do realise we're some of the best gamers in the world, right?
I am running a 560ti 448 core, maxed out at 1920x1080 and it isn't even stressing it...
Wasn't meant to be arrogant, more a "don't compare game difficulty based on a bunch of nerds who have played 24/7 since release who have a history of being great at team-based games".
Ok, so in short, INT and weapon damage are priority on main handed weapons for WD's?
You guys just using fraps to find framerate?
I didn't even think to check if it had a benchmark feature.
Question for those with the Collector's edition. If I have already registered a key to my Battle.net account using a standard edition (shop bought, not from Blizz), am I able to add the features from the Collector's edition to that account or will I have to re-register using the CE key? What will happen with my Standard edition account? Can I transfer that to another Battle.net account?
i5 2500 3.3GHz
8GB DDR3
5850 1GB
Stuttering really badly.It's not FPS lag as such. My FPS Will dip to 57-57-59-60 and it'll just stutter.
Woop! Just completed it on normal. Confused though as it says I have only played for 10hrs 59mins. I didn't rush anything so I think that might be a little off.
