Caporegime
- 7 Apr 2008
- Lorville - Hurston
You cannot go a season without losing without a large slice of luck, its as simple as that. If a team like Barcelona can't do it then it relies on a lot of luck. The current Barca side would rinse Arsenal of 03-04.
LOL not a chance. it would be a pretty tight affair. This current Barca sides' defence for instance is SHOCKING compared to arsenals defence in the invincible season.
Chelsea made Barca look silly defensively recently and RM did the same too.
BARCA's defence is shocking. as bad arsenal of today. probably worse as they are MUCH MORE gong-ho then arsenal of today.
