Caporegime
- 9 Nov 2009
- Planet Earth
Indeed. AMD are meant to be better for HTPC but for laptops I think the new IB mobile processors will probably out do the Llano processors but I guess we will find out soon enough.
Trinity looks OK. Better lightly threaded CPU perfomance,and better GPU performance overall than Llano with better battery life. Considering that AMD are still stuck on 32NM,the battery life improvements are decent IMHO.
The HD4000 IGP can catch up with the HD7660G in certain instances although it does seem to be a combination of the CPU performance of the Core i7 CPUs tested and some driver issues on the AMD side. However,the tests were 45W TDP Core i7 quad cores which probably will be in much higher level models than the 35W TDP A10 CPUs.
It will be interesting to see how the 35W TDP IB Core i3 and Core i5 CPUs do though. CPU performance will be lower overall than the Core i7 quad cores and the HD4000 IGPs in these have lower Turbo Boost frequencies(the lower TDP of these CPUs also means less higher frequency boosts I suspect).
Having said that the better OpenCL implementation on the AMD IGPs does seem to help performance on the CPU side with the A10.
Pricing is going to be the key IMHO.
I suspect it will be the same as before overall. You want mostly decent CPU performance,go with Intel,if you game on a budget then AMD looks better and if you are doing basic stuff,get the cheapest. I do think though if the Trinity laptops are priced well,they should be not too bad for all round use IMHO.
Then of course one should consider the clearance deals on the previous generation laptops which muddies the waters a bit.
