Really, so you are suggesting selling all blues and yellows and oranges via trader and using the money to buy essences on the AH?
I am struggling to find gems, as I need Topaz for +INT... So yea, might try out what you suggest tonight.
How do you know if its tier gearGems start dropping in act II and by late act III I'm starting to find regular types (tier 3). Course the problem there is, the highest you can train the jeweler to on normal is Flawless and even Perfect/Radiant seem to be oddly cheap for anything but Ruby. Its not as if you lose anything either since you can just remove the gem once you're done with it and sell it or combine it into a higher tier.
my wizard has just got ridiculous on the aoe.
chain lightning hitting 6 + disintegrate wide beam + multiple blizzard![]()
That seems to be the best way unless my maths is horribly wrong.
Most magics sell for 50-150 and yield 1 subtle essence and rarely a fallen tooth, rares are 100-300 and yield 1 of each. To buy an Essence on the AH costs about 15-25 gold each (and you can buy in bulk) and Teeth are maybe 20-35 gold so all you do is lose money by salvaging so I can't understand why they are so cheap.
Nope. Mobs scale/descale (for want of a better word) when people join/leave games. I just want to finish it by myself first.
Exactly what I'm using
My skillbar is Electrocute - Chain Lightning. Disintegrate - Convergence. Diamond Skin - Prism. Wave of Force - First rune (stuns for 2s). Blizzard (no runes yet). Archon (no runes yet).
Archon is just so powerful. A zero cost wide effect beam that deals 300% weapon damage? 15s +1s per kill duration, I've had it last almost 100 seconds in the right place!
Edit: What do you mean tier gear? Chipped, Flawed, Regular so I just assume its a tier 3 gem.
how do you have both wave of force and blizzard on bar?
Enable elective mode in options
Got it for £35 from the catalogue shop beginning with A, of all places.Where's the cheapest place to get this? Preferably instant key delivery!!![]()
