I havent come across that one. I've tried a lot of MKVs and they worked fine. What audio\video codec are you using and what build of openelec\XBMC are you on?
EDIT - Just came across this on the forums which may help - If you are on composite video.
Need to set "audio output device" to "analogue (OMX)".
Note: setting "Audio output" to "Analogue" is not sufficient.
Basically we can only drive one of composite or HDMI. And the opening the HDMI audio means the composite gets shut down…
