Looks like a nice cycle!
How did you measure your vert? I've always wanted to get it done properly. 55" is huge, why didn't you get a video
The vertical pole has inch markers along the side - it's not hugely scientific or accurate, but I'd rather jump over a bar like a high jump bar than try to jump onto a box and land on my face!
When I get my confidence back I'll start box jumping again.
How were you doing it? Did you tuck your knees or were your legs straight?
That program looks really nice, very well rounded. How will you structure your mobility work with that, will it be a typical scenario where you do some bad areas each session and then spend a bit of time on the non-major things here and there? Or are you just going to hammer it all at once
Legs tucked! I'm not a flea!
I do the mobility before each session - i.e. lower mobility for a lower session, upper mobility for an upper session, and do both on my conditioning sessions.
Foam rolling I do a lot of before the session no matter what. I really need to sort out my hip tightness, so will tend to always do some hip/hamstring mobility before each session.
Yeah I'm quite happy with that programme. Snatch deadlifts are hard though as are towel chins.
Mobility work never moistened a ladys undercarriage, remember that.
Not so sure about that, by becoming more mobile, you are then able to lift more weight, which makes you stronger, and therefore more bear like. Now you know I'm the last person to be bothered about aesthetics, and I can make women moist just by looking at them - some of us just have that gift
However, as beastly strong as I was, my form wasn't great, and I wasn't progressing and I was tight, inflexible, and just living day to day life was miserable. Now, I'm more mobile, less sore, and I don't look like a piece of 2x4 everytime I move around. My core strength has hugely improved, as has my flexibility, and whilst my strength isn't back to what it was, yet, I am 10kg lighter and still shifting over 5x my bodyweight in the 3 lifts, I'm in a lot less joint pain, and if I get the opportunity to lift weights better and reduce injury or tap into my potential, it makes sense to do it.
Either way, there is so much research that myofascial releases and mobility work are absolutely essential and good for people like us who do lift a lot of wieghts and spend hours in front of a computer.
It's also not natural not do it - it also feels great, and furthermore, it serves as a great warm up.
I started doing it a couple of years ago when I realised that I was a tight ball of knots. Since then I'm tucking in less on squats, my shoulder rotation and mobility is greatly improved despite my injury, and I actually feel less cumbersome as a result in my movements, I'm more agile and fluid.
