- 29 Aug 2010
- Cornwall
Hi all.
I had a gaming PC that I was happy enough with, but then decided I wanted to try watercooling. Rather than mess around with my gaming PC I built a new for my watercooling experiement. This was all fien and well and I'm glad I did it this way as it wasn't without it's hiccups. However, I'm finding that I don't really use both PCs, it's rare I need a second PC to do something on (like video encoding) while gaming on the other one. So one sits idle.
So I'm looking to move to 1 REALLY nice gaming PC rather than an OK gaming PC and a good gaming PC.
At the minute I'm just trying to get a feel for what I could get and what it's likely to cost. I'm not 100% committing to this yet. So if it's a case of wait a month for this or that to be released that shouldn't be too much of an issue.
Assuming I've not missed the offer I was thinking of going for 3 of the 120Hz 3D Samsung monitors for ~£500 (after claiming money back from Samsung). So I'd like a PC powerful enough to game across these three monitors.
I'll probably also get a new and likely more expensive Mouse and Keyboard.
My current systems, in case anything can be re-used are:
Watercooled system:
AMD Phenom II X6 1055T
Asus AM3+ M5A99X EVO motherboard
8GB (2 x 4GB) Corsair Vengence Blue LP
Asus GTX 480
Asus Xonar DG 5.1 soundcard
128GB Crucial M4 SSD
120GB Corsair Force 3 SSD
1TB Sasung F3 HDD
Antec Quattro 850W PSU
CoolerMaster HAF 932 case
LiteOn DVD-RW
Lamptron FC5 V2 fan controller
HeatKiller 3.0 CU CPU block
XSPC GTX 480 Razor GPU block
Black Ice SR-1 360 Rad
EK CoolStream XT 120mm Rad
Swiftech MCP35X pump
XSPC dual bay res for 1 DDC pump
4 x Gentle Typhoon AP-15s
Logitech MX518
Logitech Media Keyboard 600
Windows 7 Home Premium Retail
Air Cooled PC:
Intel i5 2500K
MSI Z68A-GD65-G3 motherboard
16GB (4 x 4GB) Corsair Vengence Blue/Black LP
2 x Palit GTX 570 (1280MB)
Creative Labs 5.1 soundcard
2 x 128GB Crucial M4 SSD
2 x 1TB Sasung F3 HDD
Corsair AX1200 PSU
LiteOn DVD-RW
Blu-Ray drive
Scythe Kaze Master Ace fan controller
Silver Arrow CPU cooler
Logitech G5
As you can see, I generally prefer Nvidia (I just seem to get on better with them) but as I was thinking of 2 x 4GB GTX680s it's hard to ignore the fact you could probably get 3 x 3GB 7970s for a similar price.
I expect I'll watercool the CPU using the SR-1 360 in the top of a HAF 932, not sure about graphics cards. If I do I was thinking of using an external 1080 rad with it's own stand. But not sure if I want to watercool the graphics cards due to the hassle, especially if I want to upgrade them at some point.
I'm tempted to go for an i7 IvyBridge chip (and Z77 or stick with Z68A?), but I'm not sure if this'll bottleneck my graphics card solution? If I want 3 x 7970s then I'll probably need to go with a X79 wont I? even if just for 3 x PCI-e lanes at decent speeds?
Hopefully from my brief discussions of GPUs and CPUs you can see what I'm aiming for. While I don't really have a budget in mind I'd obviously like to keep the cost as low as I can (hence the listing of current parts available for re-use).
I'm also tempted to get a half decent but not over ridiculous laptop that might cope with some light gaming. But really want the laptop to be portable.
If there are better monitors for triple screen setup that cost the same or less please feel free to suggest these too.
Thanks.
Watercooled system:
Asus GTX 480
1TB Sasung F3 HDD
LiteOn DVD-RW
Logitech MX518
Air Cooled PC:
Intel i5 2500K
Corsair AX1200 PSU
LiteOn DVD-RW
Blu-Ray drive
Logitech G5
Thanks.
