Please explainGiffgaff is unlimited internet. That doesn't include downloads which you have to pay a lot for.
I think you have that wrong mateWell you can browse the internet as much as you want, but if you download things like email or videos through other apps, then you have to pay extra. AFAIK
Huawei Ascend G300 - 1GHz CPU, 512MB RAM, 4" screen, 5MP camera w/flash and it's guaranteed to get Ice Cream Sandwich and all for £100.
Better than the Monte Carlo and San Francisco.
Unlock it and then put a giffgaff sim in and all should be good!
what about this then
Mobile Web
Name: O2 Mobile Web
APN: mobile.o2.co.uk
UserName: web
Password: web
MCC: 234
MNC: 10
APN Type: default
And Post Pay,
Name: O2 Post Pay
APN: wap.o2.co.uk
UserName: o2wap
Password: password
MMSC: http://mmsc.mms.o2.co.uk:8002
MMS Proxy: 193.113.200.195
MMS Port: 8080
MCC: 234
MNC: 10
APN Type: mms
just found this,if this fails i am out of ideas mateSettings - GPRS WAP & MMS
Please note all steps must be completed to ensure the settings are correctly configured.
Please ensure that when entering O2 into the settings that the letter O is selected and not a zero.
When entering the following information do not press Save until told to in the instructions.
- Press the Menu key
- Tap Settings
- Tap Wireless & networks
- Tap Mobile networks
- Tap Access Point Names
- Tap New APN
- Tap Name then tap the text box and enter O2 Pay Monthly MMS then tap OK
- Tap APN thentap the text box and enter wap.o2.co.uk then tap OK
- Tap Proxy then tap the text box and enter 193.113.200.195 then tap OK
- Tap Port then tap the text box and enter 8080 then tap OK
- Tap Username then tap the text box and enter o2wap then tap OK
- Tap Password then tap the text box and enter password then tap OK
- Skip past Server as this is preset as Not set
- Tap MMSC then tap the text box and enter http://mmsc.mms.o2.co.uk:8002 then tap OK
- Tap MMS proxy then tap the text box and enter 193.113.200.195 then tap OK
- Tap MMS port then tap the text box and enter 8080 then tap OK
- Tap MCC then tap the text box and enter 234 then tap OK
- Tap MNC then tap the text box and enter 10 then tap OK
- Tap Save
- Press the Back key four times to return to the standby screen.
What to do next
Switch your handset off and then back on to complete your settings.
The settings are now complete.
However, if you are still experiencing any issues using this service, please contact O2 Customer Services.
