Done like a pro![]()
Well I'm being honest, when I first tried mx-4 and saw the temps go up it was facepalm time, then when I saw the results with liquid pro felt like going on a bender.
The IHS is made from Nickel plated Copper as far as I know.Tempted to swap my 990x for one of these, as replacing TIM seems to help. So the IHS is fully steel? Might mill a full copper one out and polish it up to see what effect this has.
Lol. If I used IC Diamond instead of liquid pro would that work? Or would using IC Diamond directly on the CPU be a bad decision?
Well since I won't be doing it until I make a custom waterloop late next year or in 2014. I guess I'll probably buy some new TIM (liquid pro probably would be the best to use) Don't suppose you could make a small guide for removing the IHS + applying the TIM etc. I know it's probably simple and such but it's always nice to have a guide line xD
I've not tried, I'll give it a go later![]()
theres a video guide on youtube
This really concerns me as I wish to place a new ivy bridge into my build. I don't plan on overclocking, yet, but will this affect it in anyway? Would the heat of a stock clocked ivy bridge match that (or be cooler) than a sandybridge?
Thank you in advance![]()
IB are actually considered cooler chips in the sense they generate less heat than SB but since they can't dissipate it as well as SB does when they are overclocked they get hotter. Even that shouldn't concern anyone![]()
If the above guys results are with the IHS replaced back onto the cpu I'm interested in doing this.
Why is the liquid pro stuff so much better at heat transfer if this is the case though?
To the guy asking about IC diamond - Warm the tube up and it spreads ok.
I probably won't use IC Diamond when I do remove my IHS and replace the time since that won't be for quite some time
