Hi,
I purchassed a Corsair H100, installed in Antec 1200.
Having problems with profiles on it, fans are constantly running at 2600 which is max, even the profile is on low. Anyone knows how to fix it? Seems like cables are connected correctly with P7P55D-E. I was checking out other forums and looks like there is no actual solution to this, its just the way it is LOUD and not controllable by user.
Maybe anyone from technical can help? I've submited RMA to Corsair yesterday which as I know will take ages to get answer from them.
Thanks.
Eliam.
Thanks.
Eliam.
