Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
My tyres are now at 4mm and 5mm at the latest service so it is time to get new tyres soon (3mm). I've rotated them so its now 5mm at the front and 4mm at the back which should last the summer I guess. I've only done 8k miles in these so these Hankook V12 doesn't last very long do they?!
So, I guess I better start saving (that with a new alloy needed or total refurb), the one I got off eBay turned out to be warped :/ Which means I better start saving!
Anyway, the stand out tyre choices are (205/45/17R) from Blackcircles, fitted for the set.
Bridgestone Potenza RE040 (84) £564.00
Bridgestone Potenza RE050A (88) £588.00
Bridgestone Potenza RE050A (84) £644.92
Michelin Pilot Sports 3 (88) £609.16
Hankook V12 Evo (88) £446.16
Continental Contact Sports 5 (88) £585.04
Continental Contact Sports 3 SSR (84) £669.40
Uniroyal Rainsport 2 (88) £495.60
Pirelli P Zero Nero (88) £552.52
The logical thing is to stick with what I had last year, which is the Hankook (paid £396!) but i feel like a change as I think I could get less road noise with a different make may be. Now, without knowing much about tyres, and i am thinking CS5 is newer than CS3, CS5 is the one to go for on that list, seeing it is not the most expensive set anyway.
Thoughts?
Thoughts?
