Tutorial: How to wire up a LED strip.
13 Jul 2009
Llanelli
This tutorial covers wiring up any old LED strip to your computer's power supply in a number of ways, but also to an independent power supply for use outside your case or on the back of your monitor or something else.
First of all if you can't be bothered with all this faffing about with bits of wire, connectors and the potential to damage your power supply or PC then you should really be looking at OcUKs extensive range of LED strips, which come with modular connectors that can be connected together to create full case lighting.
http://www.overclockers.co.uk/productlist.php?groupid=701&catid=1428&subid=1430&rows=0
Anything you decide to do with LED strips from this guide is your responsibility. I accept no responsibility for anything you do so don't even think of blaming me for something you've done wrong. None of the voltages inside a PC case (PSU excluded) can actually hurt you.
Things you will need:-
1) Some sort of mating half for a PSU or motherboard connector. eg Molex, fan connector.
2) A soldering iron, and some flux cored solder
3) Heatshrink
4) Something to cut and strip with. A pair of wire cutters, knife or scissors will do.
If you don't have a soldering iron or heatshrink then you can twist wires together and cover them with insulation tape in a colour of your choice. It's not a permanent solution and may come undone at some stage but it's better than nothing.
So what is a LED strip anyway?
A LED strip is a string of small Light Emitting Diodes, usually surface mounted onto a long thin strip of flexible plastic material. The LEDs themselves are semi-conductors that produce coloured light when a current flows through them. LEDs are one way devices, meaning that if you wire it up wrong nothing happens as current can only flow in onhe direction. If you wire it back to front it won't blow your PSU or motherboard, it'll just not work, which is a good thing I suppose if you fear for your components.
Here are a few different types of LED strip.
RGB 60 per metre
RGB 30 per metre
Some waterproof flexible one
And the cheapest type. 15 SMD per 30cm and waterproof. The LEDs are tiny little things but do produce some decent light.
Here is one lighting up a plate drawer, the spread of light is quite uniform and fills a lot of the space.
Unlike the official LED strips from the likes of Bitfenix the cheaper strips will often come without connectors and just have two bared ends. The problem here is how on earth do we get this connected up to our PC to give it the light giving voltage and current any LED needs?
There are a number of ways you can do this.
Use a molex extender, splitter thing.
Use an old fan cable and connector...
..use whatever this thing is..
..or this..
..even the connector of a long since binned Tri-cool would do the job.
So basically we can hack and chop up a Molex or a fan connector. Everyone has either a Molex or a fan connector available, if not here's one..
http://www.overclockers.co.uk/showproduct.php?prodid=CB-012-AK&groupid=1929&catid=153&subcat=
First up I hacked a Molex to Molex fan adapter cable, like the first pictured above and the one linked to for sale.
First off we need to cut the fan connector off
Then, strip the wires and tin them if you are using a soldering iron. Put some heatshrink on the wires here if you have any. The red wire will be your +12v wire and the black will be the 0v, or ground, or -ve if you prefer.
Some LED strips will come with two same colour wires, or maybe one will have a stripe. The one with the stripe will probably be your 'Red', usually anyway. If you wish to test polarity wire up your bared ends to a 9v PP3 battery. The terminals are marked + and - so you can easily work out which wire needs to go to the Yellow or Red on your Molex and which needs to go the black.
Now basically join the red and black wires together using the soldering iron, or if you dont have one just twist the wires together.
So you end up with something like this
The good thing about this method is that if you have two strips you can easily shove another Molex into the free end of the first and daisy chain them.
Next up we have the fan connector. Here's one I cut off a Xilence 80mm fan which I never used.
Same drill, strip the wires and tin them.
Bung some heatshrink on. I usually forget to do this and have to resolder but that's just the fun of doing stuff.
Same drill as before. Join red to red and black to black. Remove the yellow wire as much as possible.
So eventually once you shrink down the heatshrink it looks a bit like this.
And connect it up..
More to come....
And for the next part I will show you how I have my internal lighting power sorted.
For this I use a Molex to Molex fan adapter.
and a mains terminal block. I only had a 3 way and 1 way available....
...but actually use an 8 way in my PC.
We need to remove one of the Molex connectors.
This nearest one is the one we want to keep, the other won't be needed so chop it off.
Here's one I chopped earlier.
We only need the Yellow (+12v) and Black (0v)
Strip back the wires and join some other wires on. I had some 1.0mm Red and Black wires kicking about so used that. I didn't use much, maybe 100mm but you can use more.
Also cut off a little bit about 40mm long and strip both sides.
..and arrange like this.
Now anything you screw into the leftmost 2 slots will be grounds and the rightmost will be +12v. Very handy if you want to wire up several LED strips, cathodes or any other device that you want. The most I've had one mine is 2 LED strips, 3 of my modded LED fans and also my illuminated front panel.
Here's the one I made just powering two strips on the bench.
Now this is interesting. A switch. One thing that I sometimes like to do is switch off my LEDs. Because I have a central distribution point for my lights I can easily switch them all on or off using a single switch.
What you need to do is break the Red (or Black) wire and solder it across the switch. What happens is that when I throw the switch the circuit is created and current can flow. When I flick it off the circuit is broken.
You can run this switch to wherever you want. All you need do is extend the broken red wire to wherever you want it.
and finally how to wire them up to an external power source. This is actually quite simple.
Here's a power source. This one isn't 12v but will be adequate to show how this works.
Cut off the DC barrel type jack somewhere near the end (but not too close so it can't be used on a future project).
Take your LED strip bare wires and solder them to the DC adaptor. You might want to test it before soldering up as it's not always easy to tell polarity. If it lights up then go for solder, if it doesn't swap the wires aorund. It's only low voltage so it won't hurt you.
And here it us working.
AC adaptors like this tend to throw out higher voltage at low current draw so even though this is only labelled as 4.5v it may well be giving 8v or thereabouts with only 50-100mA draw.
A proper regulated DC power supply would be recommended for this sort of light use but I probably wouldn't bother and just grab a £2 or £3 '12v 1A' plug in power supply like you can get on eBay.
Looks basic but only because of what i already know, Nice tut might help afew people who are wanting different ammounts and lengths of LED's/SMD's etc
could I wire a regular dc led strip to usb?
You could wire it up yes. However it wouldn't work too well as LEDs need a certain voltage to illuminate and the amount of light they would generate at just 5v would either be nothing or very little, depending on the colour of your LEDs.
The majority of LED strips are 12v as they are used on cars as well as PCs. I couldn't find any for 5v use, or at least not like the other strips you can buy.
Nice guide looking forward to the finished result. Would be good if we could get this stickied, could do with this when I come to rig my own LEDs
That looks really doable. I may give this a little try for fun over the summer :)
Thanks for the guide!
Is colour control achievable?
There is some RGB 5v SMD's out there but there all singular and you would need to make some kind of board/tape design yourself. Probably easier keeping to 12v
Thank you, Very nice!
What about the RGB LED strips?
Do they wireup the same way?
No they don't unfortunately. I only included them as images to show the different appearance. With those that I pictured I also have an RGB PWM controller box, which varies the colour of each of the red green and blue LEDs that make up the leds. Dealing with three circuits rather than just one really does make them a lot more complicated.
Still when you get the RGB strip you usually get everything you need including remote and PWM box, maybe even the PSU.
External PSU in the RGB lighting kit is what puts me off!
If you could do a tutorial on wiring RGB lighting kit which has a control box and remote to the internal PC PSU would be appreciated!
That's simplicity itself. Get a molex to molex connector extension, remove female molex (that's the one the same as on the PSU), remove red and black wires (we don't need 5v), strip yellow and black wires and solder to a relevant sized DC barrel type jack that the control box requires. The only thing you have to watch out for is polarity of the DC jack, most things need +ve to the centre and -ve to the barrel. In fact my control box even has a little picture to tell me which way around the voltage should be.
DC jacks can be bought on eBay and the Molex to Molex can be bought here on OcUK.
10 minutes is all it would take, once you have the parts anyway.
I've updated Post #2 with two new methods.
Ahh ok :)
I was more concerned about the required current/voltage mismatching!
Provided you use the correct colour PSU wires they should always be an expected voltage. Yellow = 12v, Red = 5v, Orange = 3.3v and Black = 0v :)
As for current you could have a 1000 Amp power supply and it would happily run a 200 milliamp RGB LED strip. The device pulls what it needs from the power source. Current flow is never a push type of arrangement. The Molex will supply enough current for several metres of RGB LED strip, even when R G and B are at full intensity.
A relatively old thread, but thought I'd show my efforts. Thank you for the guide.
Any constructive criticism is very welcome!
I've used two 30cm, 15LED SMD strips connected to a molex on my PSU.
I wanted to be able to unplug them easily so I've used a USB cable. The molex wires were cut off and connected to a female USB connector. Then the SMDs were wired up to a male USB connector.
I'm wondering about a third strip along the top so it is more even?
