- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi
I have been working hard to improve our range of products within the Thermal Material Range. We have more unique SKU's and a bigger range of sizes within these products!
You need not go anywhere else now for your thermal paste/tape/cleaning needs!
Alpenföhn "Snow Cannon" Thermalpaste (1.6g) @ £7.99 inc VAT
The Alpenföhn "snow cannon" is a high-end thermal compound based on silicone.
It provides excellent thermal conductivity value of 1.134 with their W / mK that the heat transfer between the CPU and the cooler is improved and fills any minute gaps. Thanks to its high viscosity even the finest grooves and filled in.
The content ranges from 1.6 grams, depending on the dosage of approximately 10 applications.
Only £7.99 inc VAT.
ORDER NOW
Akasa TIM Kit Thermal Compound + Cleaner & Spreader @ £8.99 inc VAT
High performance AK-455 thermal compound has an advanced formula designed to maximise heat transfer from chipset/CPU to the heatsink enabling you to get more from your existing cooler. The high viscosity formula efficiently fills invisible surface imperfections to improve contact and thermal conductivity.
5g thermal compound syringe enough for 10-15 CPU cooler installations and 125ml bottle of TIM Clean will last for even more CPU surface preparations. TIM kit is a must have for every PC enthusiasts.
- Designed for all types of PC CPU's, GPU’s and chipsets
- Suitable for high wattage CPU’s
- Thermally advanced for maximum cooler performance
- Spreader card makes applying thermal compound easy
- TIM-Clean leaves no residue
Only £8.99 inc VAT.
ORDER NOW
Akasa AK-TT12-80 Thermal Adhesive Tape @ £2.99 inc VAT
Akasa double-sided thermal adhesive tape is a highly effective thermal interface designed for bonding heatsinks to chipsets or other components requiring strong fixing in a hot environment.
Only £2.99 inc VAT.
ORDER NOW
Akasa AK-TC TIM Clean CPU & Heatsink Cleaner @ £5.99 inc VAT
TIM Clean fluid removes all thermal pads and silver based thermal grease from the base of heatsinks and CPU surface. TIM Clean is a citrus based solvent and is safe to use.
Only £5.99 inc VAT.
ORDER NOW
Akasa AK-455 Thermal Compound @ £2.99 inc VAT
AK-455 is a new improved formulated thermal compound that gives high performance heat transfer between the CPU and heatsink. Minimised resistance and maximised efficiency truly enables you to get more from your cooler.
- High performance heat transfer between the CPU and heatsink
- Maximum thermal conductivity: 2.4W/mK
- Easy to apply
- Multi-language instructions included
Only £2.99 inc VAT.
ORDER NOW
Akasa AK-460 High Performance Thermal Compund (3.5g) @ £3.98 inc VAT
An evolution in silicone technology delivers outstanding thermal performance.Pro-grade Silicone technology provides a stable thermal compound which delivers a great thermal performance. Minimised resistance and maximised efficiency truly enables you to get a lot more from your cooler. RoHS compliant.
- Outstanding performance of heat transfer between CPU and heatsink
- Low thermal resistance for heat transfer, 0.16cm²C/W @60 um BLT
- Maximum thermal conductivity, 3.3W/mK
- Electrically non-conductive
- Low bleed under high pressure
Only £3.98 inc VAT.
ORDER NOW
Arctic Silver Alumina Thermal Adhesive (5g) @ £6.98 inc VAT
Arctic Alumina Adhesive uses a layered composite of aluminum oxide and boron nitride. Arctic Alumina Adhesive is a pure electrical insulator, neither electrically conductive nor capacitive.
- Components:
A set of Arctic Alumina Thermal Adhesive consists of two syringes containing a total of 5 grams of adhesive (2.5 grams each of parts A and B) and a plastic reusable mixing wand. Approximately 3cc total adhesive.
Although lighter per set than Arctic Silver Adhesive due to its use of ceramics rather than silver, each set of Arctic Alumina Adhesive contains the same amount of adhesive by volume as a set of Arctic Silver adhesive and will cover the same area.
- Storage: Arctic Alumina Thermal Adhesive should be kept cold and away from UV light (sunlight and florescent lighting). We recommend refrigerating the unused material and allowing it to come to room temperature prior to use.
Only £6.98 inc VAT.
ORDER NOW
Arctic Silver Alumina Thermal Paste (1.75g) @ £3.98 inc VAT
Arctic Alumina uses a layered composite of three unique shapes and sizes of ceramic particles to maximize particle-to-particle contact area and thermal transfer. This exclusive combination provides performance exceeding most metal based compounds.
Arctic Alumina does not contain any silicone. The suspension fluid is a proprietary mixture of advanced polysynthetic oils that work together to provide three distinctive functional phases. As it comes from the syringe, Arctic Alumina's consistency is engineered for easy application in a thin even layer. During the CPU's initial use, the compound thins out to enhance the filling of the microscopic valleys and ensure the best physical contact between the heatsink and the CPU core. Then the compound thickens slightly over the next 50 to 200 hours of use to its final consistency designed for long-term stability.
Only £3.98 inc VAT.
ORDER NOW
Arctic Silver Alumina Thermal Paste (14g) @ £6.98 inc VAT
Only £6.98 inc VAT.
ORDER NOW
Arctic Silver Céramique 2 Thermal Paste (25g) @ £9.98 inc VAT
Like the original Céramique, Céramique 2 uses only ceramic fillers so it is neither electrically conductive nor capacitive. The tri-linear composite of aluminum oxide, zinc oxide and boron nitride allows the thinnest possible bond line with modern processors, heatsinks and electronics. Critically-sized particles and new ultra-high shear mixing techniques maximize Céramique 2's thermal performance and help maintain a stable homogenous suspension. This exclusive combination provides performance exceeding most metal based compounds.
- Excellent Stability: Céramique 2 is engineered to not separate, run, migrate, or bleed.
- Electrical Insulator: Céramique 2 does not contain any metal or other electrically conductive materials. It is a pure electrical insulator, neither electrically conductive nor capacitive.
- Performance: 2 to 10 degrees centigrade lower CPU full load core temperatures than standard thermal compounds or thermal pads when measured with a calibrated thermal diode imbedded in the CPU core.
- Innovative Dispenser: The amount of compound remaining in the 2.7-gram syringe is easy to determine as the rear of the plunger is perfectly flush with the flange when the syringe is empty.
- Easy Clean Up: Céramique 2 can easily be cleaned from CPUs and heatsinks with ArctiClean, isopropyl alcohol or any of the cleaners listed in the product instructions.
Only £9.98 inc VAT.
ORDER NOW
Arctic Silver Céramique 2 Thermal Paste (2.7g) @ £2.99 inc VAT
Only £2.99 inc VAT.
ORDER NOW
Arctic Silver Premium Silver Thermal Adhesive (7g) @ £12.98 inc VAT
Arctic Silver Thermal Adhesive was formulated to conduct heat, not electricity. NOTE: Even though Arctic Silver Thermal Adhesive is specifically engineered for high electrical resistance, it should be kept away from electrical traces, pins, and leads. The cured adhesive is slightly capacitive and could potentially cause problems if it bridged two close-proximity electrical paths.
- 40C to >150C (Bond strength is slightly weakened at temperatures below 0C due to crystallization.)
- Made with 99.8% pure micronized silver.
- 62% to 65% silver content by weight. Superior thermal performance.
Only £12.98 inc VAT.
ORDER NOW
Arctic Silver 5 Thermal Compound (3.5g) @ £8.99 inc VAT
Introducing Arctic Silver 5 With its unique high-density filling of micronized silver and enhanced thermally conductive ceramic particles, Arctic Silver 5 provides a new level of performance and stability. Now available at Arctic Silver dealers worldwide, Arctic Silver 5 is definitely The New Reference. Arctic Silver 5 is optimized for use between modern high-power CPUs and high performance heatsinks or water-cooling solutions. Arctic Silver 5 uses three unique shapes and sizes of 99.9% pure silver particles to maximize particle-to-particle contact area and thermal transfer.
Only £8.99 inc VAT.
ORDER NOW
Arctic Silver 5 Thermal Compound (12g) @ £19.99 inc VAT
Only £19.99 inc VAT.
ORDER NOW
Arctic Silver ArctiClean Thermal Material Remover and Surface Purifier - 60ml Kit @ £6.98 inc VAT
ArctiClean 1 Thermal Material Remover quickly emulsifies and dissolves the existing thermal grease or pad from the CPU and/or heatsink so that it can easily be removed with a clean cloth or paper towel. A few drops of ArctiClean 2 Thermal Surface Purifier and some gentle wiping then removes the remaining residue and inhibits flash corrosion on copper or aluminum.
Only £6.98 inc VAT.
ORDER NOW
Arctic Cooling MX-2 Thermal Compound (1g) @ £0.59 inc VAT
Turbo MX-2 is a high conductive and low resistance compound for components that require the best thermal dissipation. MX-2 is ideally suited for use in CPU, GPU cooling and other applications between power semiconductor components and heat sinks where high thermal conductivity is critical. Since the MX-2 compound does not contain any metal particles, there are no problems regarding electrical conductivity and capacitance. In contrast to silver and copper compounds, contact with electrical traces, pins, and leads cannot result in any damage. Curing and bleeding of the compound is not possible. In contrast to metal or silicon pastes, this compound does not show decreasing performance over time, does not need to be reapplied and has a durability of at least 8 years.
- High Thermal Conductivity
- Low Thermal Resistance
- Non-Electrical Conductive
- Non-Capacitive
- Non-Curing
- Non-Corrosive
- No Bleeding
- Odourless
Only £0.59 inc VAT.
ORDER NOW
Arctic Cooling MX-2 Thermal Compound (4g) @ £6.98 inc VAT
- Non-Capacitive
- Non-Curing
- Non-Corrosive
- No Bleeding
- Odourless
Only £6.98 inc VAT.
ORDER NOW
Arctic Cooling MX-2 Thermal Compound (8g) @ £8.99 inc VAT
- Non-Capacitive
- Non-Curing
- Non-Corrosive
- No Bleeding
- Odourless
Only £8.99 inc VAT.
ORDER NOW
Arctic Cooling MX-2 Thermal Compound (30g) @ £14.99 inc VAT
- Non-Capacitive
- Non-Curing
- Non-Corrosive
- No Bleeding
- Odourless
Only £14.99 inc VAT.
ORDER NOW
Arctic Cooling MX-2 Thermal Compound (65g) @ £29.99 inc VAT
- Non-Capacitive
- Non-Curing
- Non-Corrosive
- No Bleeding
- Odourless
Only £29.99 inc VAT.
ORDER NOW
Arctic Cooling MX-4 Thermal Compound (4g) @ £8.99 inc VAT
ARCTIC MX-4 is a new thermal compound that guarantees exceptional heat dissipation from components and maintains the needed stability to push your computer system to its maximum. Similar to the performance of existing and acclaimed ARCTIC MX-series, ARCTIC MX-4 continues to be overclocker’s ultimate choice when choosing thermal compounds. Prior to its introduction into the market, ARCTIC MX-4 has already received a Top Product Award from PC Games Hardware in a Germany print magazine in August 2010 as it prevailed against 11 other thermal compounds in the market. The ARCTIC MX-4 is a premium-grade thermal paste with exceptional performance and ease of application. It is an electrically non-conductive paste that is applied between CPU/GPU and designated coolers to transfer the dissipated heat from the components to the heat sink. Since the ARCTIC MX-4 is a metal-free compound, it eliminates the risks of causing short circuit and in turn adding more protection to your computer. The new formula in the ARCTIC MX-4 features optimal thermal conductivity and low thermal resistance. These characteristics effectively dissipate the emitted heat from the core components. The consistency of the ARCTIC MX-4 is designed for simple application. Its texture is just thin enough to spread onto components using fingers without creating much mess.
- Easy Application
- Optimal Thermal Conductivity
- Non-Capacitive
- Non-Corrosive
- No Curing
- No Bleeding
- Thermal conductivity: 8.5 W / mK
- Viscosity: 870 poise
- Density: 2.5 g/cm3
Only £8.99 inc VAT.
ORDER NOW
Arctic Cooling MX-4 Thermal Compound (20g) @ £19.99 inc VAT
- Easy Application
- Non-Capacitive
- Non-Corrosive
- No Curing
- No Bleeding
ORDER NOW
Cooler Master IC-Essential E1 Thermal Paste @ £3.98 inc VAT
The IC Essential E1 is a high performance thermal compound to meet the requirements of mainstream CPU cooling. With its low thermal impedance and appropriate viscosity, IC Essential E1 can provide very efficient heat transfer and can be spread easily and evenly. It's also bundled with a grease cleanser that allows you to easily clean old thermal grease away.
- Electrically Non-Conductive
- Non-Curing
- Non-Capacitive
- Non-Corrosive
- Grease cleanser included for easy cleaning away old thermal grease
Only £3.98 inc VAT.
ORDER NOW
Cooler Master IC-Essential E2 Thermal Paste @ £3.98 inc VAT
The IC Essential E2 is a high performance thermal compound to meet the requirements of mainstream CPU cooling. With its low thermal impedance and appropriate viscosity, IC Essential E2 can provide very efficient heat transfer and can be spread easily and evenly. It's also bundled with a grease cleanser that allows you to easily clean old thermal grease away.
- Gold Coloured
- Non-Curing
- Non-Capacitive
- Non-Corrosive
Only £3.98 inc VAT.
ORDER NOW
Cooler Master IC-Value V1 Thermal Paste @ £2.99 inc VAT
The IC Value V1 is a high performance thermal compound with high thermal conductivity and low thermal resistance. It can prevent your pc components from short circuit incidence due to its traits of non-curing and non-electrical conductive. The IC Value V1 can achieve very efficient heat dissipation and is ideal for CPU, GPU cooling or other applications.
- Non-Curing
- Non-Capacitive
- Non-Corrosive
Only £2.99 inc VAT.
ORDER NOW
Coollaboratory Liquid Cleaning Set @ £7.99 inc VAT
The Coollaboratory Liquid Cleaning Set enables a fast, simple and effective removal of impurities and residues of heat conduction pastes from metallic contact surfaces in PC-systems. It also prepares the surfaces of processors and coolers for the usage of a new heat conduction paste on base of silicone, glycerin or metal optimally.
The set contains three components, which provide an excellent cleaning when using correctly.
- Phase 1: Preparation
- Phase 2: Cleaner
- Phase 3: Metal Cleaner
The Liquid Cleaning Set - Phase 3 was designed especially for metallic surfaces (copper, nickel, aluminum etc.)
Only £7.99 inc VAT.
ORDER NOW
Coollaboratory Liquid MetalPad - PS3/XBOX360 @ £8.99 inc VAT
The innovation in the cooling of processors from High-End PC systems, notebooks and game consoles with a heat conduction pad!
The Coollaboratory Liquid MetalPad ist the first heat conduction pad, which is composed of 100% metal and melts with just less heating (BurnIn-process), then it confects its superior heat transfer. It dissipates the heat fast and efficiently and needn´t hide from the best heat conduction paste. The simple, clean and fast installation turns the Liquid MetalPad into the ultimate heat conduction medium for HighEnd PCs and game consoles.
The Liquid MetalPad can be used with all on the cooling market commercially available materials, for instance aluminum or copper! It doesn´t age and doesn´t have to exchange regular. The Coollaboratory Liquid MetalPad is certainly RoHS conformable and absolute nontoxic.
The Coollaboratory Liquid MetalPad is delivered in a transparent blister-package and contained depending on the variant one or several Liquid MetalPads. The Liquid MetalPads are available for CPU's (ca. 38x38mm), GPU's (ca. 20x20mm) and game consoles (ca. 42x42mm). Additionally there is a detailed printed manual included and according to the product variant a cleaning set for removal / cleaning of the contact area before and after using the Liquid MetalPad.
Only £8.99 inc VAT.
ORDER NOW
Coollaboratory Liquid MetalPad - 3 x GPU Thermal Pads @ £7.99 inc VAT
Only £7.99 inc VAT.
ORDER NOW
Coollaboratory Liquid MetalPad - 3 x CPU Thermal Pads @ £8.99 inc VAT
Only £8.99 inc VAT.
ORDER NOW
Coollaboratory Liquid MetalPad - 3 x GPU & 3 x CPU Thermal Pads @ £12.98 inc VAT
ORDER NOW
Coollaboratory Liquid MetalPad - 1 x CPU Thermal Pad @ £4.99 inc VAT
Only £4.99 inc VAT.
ORDER NOW
Coollaboratory Liquid MetalPad - 1 x GPU Thermal Pad @ £4.99 inc VAT
Only £4.99 inc VAT.
ORDER NOW
Coollaboratory Liquid Ultra Thermal Paste @ £8.99 inc VAT
nonl2br
After the overwhelming success of the Liquid Pro, the new Coollaboratory Liquid Ultra was developed. Of course the Liquid Ultra is also made of 100% metal, but it has an absolute new usability and offers an outstanding performance. Due to the paste-like texture the application is now very easy.<br>
<br>
The Coollaboratory Liquid Ultra was optimized for highest performance and optimal usability. The thermal compound consists to 100% of metal, but can be applied very easy with a commercial brush. The processor (Heatspreader) should be cleaned thoroughly before apply the Liquid Ultra, in order to eliminate dirt, old thermal compound or fat.<br>
<br>
<iframe width="560" height="315" src="
" frameborder="0" allowfullscreen></iframe> <iframe width="560" height="315" src="
<br><br>
Depending on the size of the Heatspreader, three to four division lines of Liquid Ultra should be applied centrically on the Heatspreader. Then the Liquid Ultra should be disposed slowly and without pressure on the Heatspreader. The less pressure is used when elapsing, the easier the Liquid Ultra can be applied. The Liquid Ultra has a pasty form, whereby the application goes very fast. Please pay attention to coat also the edges of the Heatspreaders. Therefore always use the same brush side. It is usually not necessary to apply more Liquid Ultra again for a commercial processor.<br>
<br>
The application is managed within 30-60 seconds on average. In the following the application is represented in a short photo distance: <br>
Only £8.99 inc VAT.
ORDER NOW
Coollaboratory Liquid Pro Liquid Metal Thermal Paste @ £8.99 inc VAT
nonl2br
Coollaboratory Liquid Pro is the first heat conducting medium, which is worthy of its name. It is the first heat conduction paste that consists of 100% liquid metal alloy. It is liquid at room temperature (like mercury), but it is absolutly nontoxic and has a high moistening ability for several materials. The Coollaboratory Liquid Pro is especially recommend for nickel-plated copper.<br>
<br>
Coollaboratory Liquid Pro contain no non-metallic additives (like silicone, oxides etc.) at all. It also does not contain any solid particles. Due to these properties, Coollaboratory Liquid Pro surpasses the best high performance heat conducting pastes by a multiple. <br>
<br>
" frameborder="0" allowfullscreen></iframe><br><br>
Only £8.99 inc VAT.
ORDER NOW
Coollaboratory Liquid Pro Liquid Metal "Demo" Kit @ £4.99 inc VAT
This "try-out bundle" has a halved content. Convince yourself of the superior performance of these thermal paste!
- Content: 0.075 ml (0.5 g)
- Includes swab
Only £4.99 inc VAT.
ORDER NOW
Coollaboratory Liquid MetalPad for Notebooks / Laptops @ £9.95 inc VAT
- 76 x 38 mm (Liquid MetalPad)
- 76 x 38 mm (copper foil, and 1x 0.1mm 1x 0.2mm thickness)
- Material: 100% metal
- Contents: Multi-lingual guide / 1x Liquid MetalPad in Case / 1 x 0.1 mm thick copper foil in Case / 1 x 0.2 mm thick copper foil in Case
Only £9.95 inc VAT.
ORDER NOW
Dimastech HTX-EE Thermal Grease - Enthusiast Edition (3.5g) @ £7.99 inc VAT
DimasTech is one of the leading suppliers of high quality, efficient and quieter cooling solutions for the PC. But a chain is only as strong as its weakest link and DimaTech have produces a new thermal compound to ensure your heatsinks work at optimal efficiency.
The HTX-EE provides a solid performance and it comes in a 3.5 gram tube.
- Material: silicone-based (non-electrically conductive)
- Content: 3.5 g
- Color: Grey
- Thermal conductivity: 8.6 W / m K
- Operating temperature: - 50 ° C to +300 ° C
Only £7.99 inc VAT.
ORDER NOW
Gelid Solutions GC-Extreme Cutting Edge Thermal Compound (3.5g) @ £8.99 inc VAT
Created for extreme users; the GC-Extreme thermal compound (3.5g) achieves the best heat conductivity from your CPU, VGA or even Chipset. The GELID applicator enables an easier application.
- Ultimate Heat Conductivity
- Non-Corrosive, Non-Curing and Non-Toxic
- No Bleeding and User Friendly
- GELID Applicator
- Net Content of 3.5g
Only £8.99 inc VAT.
ORDER NOW
IC Diamond Perihelion Ceramic Thermal Compound - (4g) @ £4.99 inc VAT
IC Perihelion is made for mid range performance geared towards the user on a budget. The ceramic based compound is suitable for all applications from a CPU Air Cooler right through to Watercooling applications and easily beats the performance of similar priced compounds. Each syringe contains 4grams of compound, enough for quite a few applications.
Only £4.99 inc VAT.
ORDER NOW
IC Diamond 24-Carat Thermal Compound (4.8g) @ £13.99 inc VAT
IC Diamond out performs all other compounds in independent user testing amoung the popular brands tested, IC Diamond contains 92% pure syntheic Diamond. Purified synthetic diamond has a thermal conductivity of 2,000-2,500 W/mKL compared to 406-429 W/mK for pure silver. IC Diamond is electrically none-conductive and none-capacitive providing protection for electrical components when used.
IC Diamonds exceptional durability is due to its high bulk loading of micronized diamond particles. Each tube of IC Diamond contains over 92% micronized diamond and ais 94% fully loaded counting other miscellaneous particles. This highly loaded mix (90% + Bulk loading) is recommended by chip manufacturers to limit pump out due to thermal cycling.
IC Diamond is a stand out amonst all compounds by providing both high performance and long term reliability. Lightly loaded or creme type pastes initially provide some preformance, however the effect can be transitory, sometimes only lasterin a couple of weeks or months. You are safe in the knowledge that IC Diamond thermal conductivity lasts forever.
Based on Independent tests IC Diamond performs 2.77°C better than OCZ Freeze, 3.28°C better than Arctic Cooling MX-3, 3.38°C better than Arctic Silver 5 and 4.74°C better than the Intel generic paste.
- Each tube of IC Diamond Thermal grease contains 7 carats of micronized diamond with diamond particle loadings @ 94% by weight. Material loading above 90% is recommended as the best combination of rheological and thermal properties to minimize interface pump out due to thermal cycling.
- Superior bulk conductivity
- Excellent thermal impedance
- Tight particle distributions
- < 40 µ maximum particle diameter
- Silicone free
- Lower viscosity
- Greater stability
- Non capacitive or electrically conductive
Only £13.99 inc VAT.
ORDER NOW
IC Diamond 7-Carat Thermal Compound (1.5g) @ £6.98 inc VAT
- Silicone free
- Lower viscosity
- Greater stability
Only £6.98 inc VAT.
ORDER NOW
Prolimatech PK-1 Nano Thermal Compound (5g) @ £7.99 inc VAT
The Prolimatech PK-1 Nano Aluminium Thermal Compound is thermal compound that is entirely environmentally safe and recyclable. Even with that being said it is at the head of the pack as far as performance, and is very easy to apply.
- Excellent long-term stability
- Non-electronically conductive
- Non-corrosive
- Easy to apply and less to use
- No "burn-in" time required
- Low dry-out
Only £7.99 inc VAT.
ORDER NOW
Prolimatech PK-1 Nano Thermal Compound (30g) @ £19.99 inc VAT
- Non-corrosive
- Low dry-out
ORDER NOW
Xigmatek PTI-G3606 Thermal Grease - (3g) @ £3.98 inc VAT
PTI-G3606 is Silicon-base thermal grease with excellent heat-conductive filler and effective thermal grease for any heat sink device where efficient cooling is required, such as CPU power transistor, and SCRs to heat sink or chassis. It will not dry out, harden, or melt even after long term exposure to temperatures up to 24°C.
- Extended Temperature limits: Peak: -20 degrees to 180 degress.
- The high-density, specifically designed for modern high-power CPUs and high-performance heat-sinks or water-cooling solutions.
- Silicon-based thermal grease has moderate thermal conductivity.
- Not electrically conductive, can't cause problems if it contacts the pins of an IC.
- High thermal conductivity > 5 W/m-K.
- At a layer 0.03" thick, one tube will cover approximately 300 square inches.
Only £3.98 inc VAT.
ORDER NOW
Only £7.99 inc VAT.
ORDER NOW
Only £8.99 inc VAT.
ORDER NOW
Only £2.99 inc VAT.
ORDER NOW
Only £5.99 inc VAT.
ORDER NOW
- Easy to apply
Only £2.99 inc VAT.
ORDER NOW
Only £3.98 inc VAT.
ORDER NOW
- Components:
Only £6.98 inc VAT.
ORDER NOW
Only £3.98 inc VAT.
ORDER NOW
Only £6.98 inc VAT.
ORDER NOW
Only £9.98 inc VAT.
ORDER NOW
Only £2.99 inc VAT.
ORDER NOW
ORDER NOW
Only £8.99 inc VAT.
ORDER NOW
ORDER NOW
Only £6.98 inc VAT.
ORDER NOW
- Non-Capacitive
- Non-Curing
- Non-Corrosive
- No Bleeding
- Odourless
Only £0.59 inc VAT.
ORDER NOW
- Non-Capacitive
- Non-Curing
- Non-Corrosive
- No Bleeding
- Odourless
Only £6.98 inc VAT.
ORDER NOW
- Non-Capacitive
- Non-Curing
- Non-Corrosive
- No Bleeding
- Odourless
Only £8.99 inc VAT.
ORDER NOW
- Non-Capacitive
- Non-Curing
- Non-Corrosive
- No Bleeding
- Odourless
ORDER NOW
- Non-Capacitive
- Non-Curing
- Non-Corrosive
- No Bleeding
- Odourless
ORDER NOW
- Easy Application
- Non-Capacitive
- Non-Corrosive
- No Curing
- No Bleeding
Only £8.99 inc VAT.
ORDER NOW
- Easy Application
- Non-Capacitive
- Non-Corrosive
- No Curing
- No Bleeding
ORDER NOW
- Non-Curing
- Non-Capacitive
- Non-Corrosive
Only £3.98 inc VAT.
ORDER NOW
- Gold Coloured
- Non-Curing
- Non-Capacitive
- Non-Corrosive
Only £3.98 inc VAT.
ORDER NOW
- Non-Curing
- Non-Capacitive
- Non-Corrosive
Only £2.99 inc VAT.
ORDER NOW
- Phase 2: Cleaner
Only £7.99 inc VAT.
ORDER NOW
Only £8.99 inc VAT.
ORDER NOW
Only £7.99 inc VAT.
ORDER NOW
Only £8.99 inc VAT.
ORDER NOW
ORDER NOW
Only £4.99 inc VAT.
ORDER NOW
Only £4.99 inc VAT.
ORDER NOW
nonl2br
<br>
<br>
<br><br>
<br>
Only £8.99 inc VAT.
ORDER NOW
nonl2br
<br>
<br>
Only £8.99 inc VAT.
ORDER NOW
- Includes swab
Only £4.99 inc VAT.
ORDER NOW
Only £9.95 inc VAT.
ORDER NOW
- Content: 3.5 g
- Color: Grey
Only £7.99 inc VAT.
ORDER NOW
- GELID Applicator
Only £8.99 inc VAT.
ORDER NOW
Only £4.99 inc VAT.
ORDER NOW
- Silicone free
- Lower viscosity
- Greater stability
ORDER NOW
- Silicone free
- Lower viscosity
- Greater stability
Only £6.98 inc VAT.
ORDER NOW
- Non-corrosive
- Low dry-out
Only £7.99 inc VAT.
ORDER NOW
- Non-corrosive
- Low dry-out
ORDER NOW
Only £3.98 inc VAT.
ORDER NOW
