Road Cycling Essentials
Status
Not open for further replies.
PANIC! I've a night shift tomorrow and my old lights will not fit my new bike!
nooooooooooooooooooooooooooooooooooooooooooo!
Are you doing it on the same day as the tour? Where are you staying? Are you riding it from the west? (is that the way the tour does it?)
We're trying to decide if we want to go and see the tour this year. My mum wants to go, but i'm not so sure. It's great to be there, up close to the riders watching them fly past up the hill, but it's so hard to follow the race away from home. It's not the same to just look at the results in the paper the next day, you miss all the excitement of what happens in each stage.
If we were going, we would be going to the Tourmalet, but that means missing pretty much the whole final week of the race. I suppose i could record it and try to watch a week's worth of racing before i hear who won. :p
I'll be doing it either the day before, or the day after. Haven't decided which yet. My wife's booked us into a cottage near Pau, so we're fairly central for about 4 stages.
If you book into a place with SKY then you can watch the ITV4 coverage every day, which is what I did last year.
Let me know if you're going to be there at the same time and we can meet up :)
Quick question..
Servicing a road bike??
What should be done and when?
Check how worn your chain is and replace if it's worn. If it's too worn you may find the new chain slips on the cassette though so a new cassette is required.
Replace the pad inserts as they are cheap as **** and it makes your rims last longer as they pick up metal off the rim as the rim wears....making it wear even more.
Even though the headset will be sealed bearings I'd strip it off and clean it all down/regrease the mating surfaces.
Hubs are BB will be sealed and I'd change them once they start to develop play in them.
If the cables feel a bit sluggish/rusty then change them too. A nice set of dura ace cables on the brakes and gears makes things work really smooth and they last ages. I also like to make sure the brakes come on and release freely without the cable attached and if not I'll clean them and oil them up a bit.
I was thinking more preventative maintenance schedule rather than waiting until something felt worn out?
How long before you service a hub? Presumably it's more often than a BB
1000 miles for a chain before replacement?
It's a new bike so I was looking to keep it that way ;)
That's the best way and a lot of folk learn the hard way. I'd say easily 1000 miles in a chain if it's dry weather. Changing it early means you can use more chains per cassette and it keeps the chainrings in good condition.
The bearings at he bottom bracket are sealed cartridge units so you can't really opening it up to grease it, same for the hubs if I remember which wheels you have.
Once they have play in it you change the cups on the BB or press in new bearings in the wheels. All you could do with the rear hub is take off the freehub body and give it all a wee clean out and a big of clean oil in there to keep it going.
I like to take my chainset off and clean all the bits you can't usually get to. Wiping it all down and using grease while assembling it again stops stuff getting siezed on. I had to use a heavy hammer+block of wood to remove a stuck shimano external cup chainset. Usually you can just push them out!
Edit: The problem I see most is people trying to clean the bike too much. They spray degreaser straight onto the cassette, which means freehub body/bearings, and then moan the hub is rough as ****. Same for the bottom bracket area when you shoot water into the BB shell that just sits in there rotting the bearings to ****. I just wipe my bike down using as little water as possible.
It's only been out in the rain once, I am trying to keep it that way too.
Always just wipe it down with a damp rag, have never used soap or degreaser on it.
It's currently done about 700 mile at a guess and wipe it down is all I've ever done.
Rims are Pro-Lite Como
July, but yes.
LMAO - 9 mins is not a long climb. I'll be going up the Tourmalet in June and will be climbing for well over an hour. That's a lot for a lad that likes his cake ;)
I can't be held responsible for your mistakes. ;)
The owner of the company I work at did a "L'Étape du Tour" last year and said that the heat was the worst part. I hope you're prepared for it!
Training twice a day now, diet going well. Can't do any more really. Have about 7 weeks to go so I'll be a minimum of 7KG lighter. Should all make a huge difference. Don't doubt I'll do it though ;)
Aren't you concerned about overtraining? I often feel as though I could do a lot more, but I keep reading that it's counterproductive.
As long as you up your workload gradually and listen to your body then overdoing it shouldn't be an issue. :)
More often than not I feel dehydrated before I feel tired. I guess I should stop worrying and just "man up".
I had an accident on the way in to work today; first collision with a car in 2 years of commuting. Fortunately the car was stationary and I managed to slow to about 5mph. I was riding up the outside of the lane, and hadn't realised that the driver of the car had stopped to let another car out of a side road. I braked but not in time to avoid the car; my bar end caught the rear wing. I was able to unclip in time and so avoided falling to the ground. No damage to the bike, and only a small dent to the car. The driver didn't seem too bothered by it and said that she'd let it go - I guess my profuse apologies had some effect. Certainly got the old adrenaline flowing!
I'm a man. How am I going to get dates right? ;)
I asked Mrs Hincapie this morning and she said we're going on the 13th July to arrive for the 14th July.
It will be cooler in the Mountains (obviously the valleys will be a different matter), but it's just going to be hard full stop. Much MTFU will be required ;)
Yes, I am. It's a fine line isn't it? I have an enforced rest day on Fridays and if I go out on a Saturday, it's for a gentle spin. Now that I'm training twice a day, the lunch time effort is more of a spin with a medium-light resistance, the main effort being in the evenings.
Speaking of training, fancy a trip to Beaconsfield this weekend? The weather should be nice, there's a load of possible routes so we can make it as long or short, challenging or easy as you feel up to. Send me an e-mail (hincapie dot george at gmail dot com) if you fancy it.
Using endomondo, does anyone know if you can combine two runs into one?
I log both my way to work and home and would like it as one. I've tried leaving it running all day but it ate my battery even with gps turned off untili left again.
Well, that's technically correct but "cooler" doesnt mean "cooler than england", it means "cooler than sea-level in the south of france" which is still a lot hotter than england!
I was in the alps to see the tour in 2010. We were standing about at about 1550m, halfway up the climb to Avoriaz. Which is slightly lower than the tourmalet, but it was still far too hot! And i wasnt even cycling!
I know, it's relative. The weather will be what it will be and I shall just have to get on with it.
I made a post asking for advise on my Club forum and the following post was quite useful:
I may hold the club altitude record at 4160 metres on the Pic de Aguilla in the Andes -- did it 4 times when late in my 60s as part of a then annual 6 - week tour. We carried our own bags which encouraged adopting Socrates' advice " take a pride in all that you don't want". Climbed the Col de Tourmalet on a 36 x 28 and was surprised at how soon the summit cafe loomed out of the mist ( it was October with an air temperature around 2 degrees ). Cycled from there thro The Alpes Maritime to get to Nice via the Col de la Bonnette ( 3000 metres and highest metalled road in Europe) The Veletta in Spain is higher but now left rough deliberately after the snow-melt to make it impassable for cars, also crossed as part of a month long tour.
So much for credentials, to answer your question : carry on with the weight-loss. I did little specific training other than lurch around from cafe to cafe on longer rides at steady pace and some shorter non-stop hillier rides of about 40 miles ( Andes tours were in January/ February.
On the actual climbs -- get to the start feeling fresh and continue staying fresh by choosing your own pace and ignoring others. I used to drink plain water -- cheap and can be poured over your head when hot -- wore a casquette rather than a helmet ( helmets not compulsory in Spain on climbs, in very hot weather or in towns ) which keeps hair nice and damp!. In the Andes I have hosed myself down at filling stations!
When wearing the smart kit I sold you, never become an object of pity. On long days when you have to stop at cafes, cool down and get composed before choosing food and drink -- will lead to better decisions. A now dead companion used to check his tyres and wipe his wheel rims with a serviette at the end of each day. I always did my laundry as I showered before enjoying a beer so that all was ready for next day as a matter of routine --saves mental energy. Enjoy it --we're only young once.
Was it along Lower Addiscombe Road?
Yes, they've turned that previously safe stretch into a dangerous hazard.
Sorry to hear that but glad you're ok. Was yours along Lower Addiscombe Road?
Unfortunately I have plans this weekend, and besides, it's much too far away for me anyway (I don't drive!).
I feel quite nervous riding down it now, as it means drivers are constantly having to stop to get around parked cars. I'm probably going to stop using it, and go along Addiscombe Road instead.
Technically, yes. It was at this junction: http://g.co/maps/f7s8x
I was on the outside, and the car had stopped to let somebody out of that side road - I couldn't stop in time (locked up the back brake in the process of trying) and caught the rear wing. I'm starting to ache now, so I must have hit it harder than I first though :|
By the way, after your last email about fixies/single speeds, I realised that I can't really justify spending any money on bikes at the moment. Thanks for your advice though; it'll come in handy for when I am in a position to buy stuff again :)
Anyone doing the Norwich 100 this sunday?
I did it last year in a total time (including rest stops) of 7hr20 (5hr50 moving time) and have set myself a target for 6hrs total this year...though thanks to the weather in the last few weeks disrupting my training (my excuse for being a bit unfit...) I'd be happy to do it in about the same this year.
Weather looks like it's going to be absolutely perfect so I'm really looking forward to it :D
Status
