***** BitFenix Prodigy Cases - Ideal for LAN events! *******
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hello
We have the UK exclusive for the new and upcoming BitFenix case. This is an amazing MiniITX case which is able to house it all.
Nvidia GTX 690 - Check
AMD Radeon 7970 - Check
240mm Radiator - Check
Multiple HDD's - Check
IvyBridge - Check
Full ATX Power Supplies - Check
Full Size Optical Drive - Check
120mm or 140mm Rear Fans - Check
Lightweight - Check
Portable - Check
Front USB3.0 - Check
Sexy, sleek, elegant - Check
These boxes are perfect for LAN players, or anyone looking for something high end but with a small footprint.
Stock will arrive the beginning of July. Get your pre-orders in now.
BitFenix Prodigy Mini-ITX Cube Case - Arctic White @ £59.99 inc VAT
Meticulously crafted and beautifully engineered, Prodigy redefines the Mini-ITX chassis. The compact housing is suspended by handles made with BitFenix FyberFlex™ Composite for easy portability and maximum shock absorption. The spacious internals give you the flexibility to install up to five 3.5" hard disks or no less than nine SSDs. The modular FlexCage™ can also be removed entirely to fit long graphics cards and water cooling radiators up to 240mm in length, and a choice of Midnight Black or Arctic White with available interchangeable face plates mean Prodigy will suit your individual style. With tool-free convenience, two USB 3.0 ports, filtered intakes, and proprietary BitFenix SofTouch™ Surface Treatment, Prodigy is the compact case with no compromises.
- Beautifully Compact – Mini ITX dimensions with clean modern styling
- Unmatched Flexibility – Supports long graphics cards and up to 240mm water cooling radiators
- BitFenix FyberFlex™ Composite Handles – For portability and shock absorption
- Maximum Storage Potential – Install up to five 3.5" or nine 2.5" SSDs
- BitFenix FlexCage™ - Modular hard disk cage can be completely removed for added flexibility
- Choose Your Own Style – Two color options and interchangeable face plates available
- SuperSpeed USB 3.0 – Two ports included for blazing file transfers
- BitFenix SofTouch™ Surface Treatment – Luxurious matte finish and soft feel
- Trouble-free Installation – Tool-free drive locking mechanisms, cable management and filtered intakes
- Dimensions (WxHxD): 250 x 404 x 359mm
- Motherboard Sizes: Mini-ITX
- 5.25” Drive Bays: x 1 (removable)
- 3.5” Drive Bays: x 5 (3 + 2 modular)
- 2.5” Drive Bays: x 9 (5 + 2 + 1 +1 )
- Cooling Front: 120mm x 2 (120mm x 1included) or 140/180/200/230mm x 1(optional)
- Cooling Rear: 120mm x 1 (included) or 140mm x 1(optional)
- Cooling Top: 120mm x 2 (optional)
- PCI Slots: x 2
- I/O: USB 3.0 x 2, HD Audio
- Power Supply: PS2 ATX (bottom, multi direction)
- Extras: FyberFlex™ Composite handles, SofTouch™ surface treatment, filtered intakes, tool-free drive locking
Only £59.99 inc VAT.
ORDER NOW
BitFenix Prodigy Mini-ITX Cube Case - Midnight Black @ £59.99 inc VAT
- PCI Slots: x 2
ORDER NOW
Oh, my gosh I want this now even more because it is in white and is £60!! Think this may be my next main case because of the capabilities :D
It'll definitely fit a GTX 690. gtx 690 isn't 240mm in length xD
I've got a prolimatech megahelam black edition in there with ease in push pull with super high ram sticks. Doesn't even bust the Asus P8Z77's extra VRM which is awesome.
