***** BitFenix Prodigy Cases - Ideal for LAN events! *******
Can someone tell me how much room they're is from the bottom of that ITX board to as far as the side panel?
EDIT: Pretty please? :)
I think it was more to accommodate long graphics cards and water cooling tute ;)
Ace isn't that the z77 asus itx board not a h77?
Nath, would that board be fine for using a Waterblock backplate?
Edit - this in white or a gunmetal grey switch 810?
Ace you could tell us the measurement from the bottom of the ITX board to the side panel? or if you can put a M-ATX board in and get the panel on? if its as big as I think it is I'll pre-order
Bottom of the ITX board, plain x
Side panel, plain y
Which length of the hypotenuse were you looking for?
Unless you are planning to cut the motherboard's extra PCI slots out on the PCB, you will not be able to place a mATX in this case horizontally. Placing it vertically you have the motherboard tray in the way, and you have the IO in the way.
And as for radiator size on the roof, if you took off the ODD, and the top hard drive, you have..... Well over 160mm depending on the VRM's and caps and ram on your motherboard.
Looking for the dimension of the Motherboard tray, and the space from the bottom of an installed ITX board (PCI-E end) to the panel, and the space between the top of the ITX board and the panel nearest to that?
EDIT: Dw, Thanks xbournex, time to sell M-ATX and buy ITX :p
Will this be able to house a Corsair H70 with 2 fans on and the optical bay not get in the way? I'm guessing I would have to remove the front HDD bay which is fine.
