ok well my pc was stable at 4.6.... IBT no probs, 10+ hours prime.... but now when playing bf3 i'm getting those WHEA triangles.... what the ****... like seriously?!even pumped up the voltage to 1.312 just on the fly through the asus AIsuite and still got them... :\ hummmm
ok now all of a sudden using the settings i used 2 days ago and ran all the test no problem....now i'm getting the whea-loggers in IBT....... starting to think this was a mistake... i enjoy the challenge... but if it's just going to change it's mind on a daily basis then i might DSR it
lol now running IBT again and no errors in event viewer... although before when playing bf3 i did get lag/stuttering, i checked the logs and i did get them at that time... is it a simple case of just pump some more volts through or is there something else we are missing?
just did a quick test at 4.5ghz, no errors during just 2 loops of ibt with volts dropped to 1.240ish... mad that even adding .06v and cant get those extra 100mhz al of a sudden... might just stick with 4.5...or when i butcher the chip and put liquid pro inside might up the volts again temp depenent. 4.5 knocked almost 10oC off the IBT temps... and it was about 4 degrees warmer in the room
