- 21 Sep 2009
- London
Agreed, but if you only play singleplayer games then they're loaded instantly.
Dave what board are you using ...to get them resultsAgreed, but if you only play singleplayer games then they're loaded instantly.
This is what i am getting on the system in my sig...and pointers to increase speed thanks
MineYours![]()
Just noticed where it gives the info on the drive where it says firmware and that yours says 1024.....mine is way higher...101888 that doesnt look right does it...mine also says ATA ...
The 1024K-OK is the disk offset of the partition, and if it's green then it's ok.
To get more speed download and run the Intel (IASTOR) driver, as I believe the MSAHCI driver is considerably slower.
11.1.0.1006 is the fastest AHCI driver http://downloadmirror.intel.com/20984/eng/STOR_Win7_XP_11.1.0.1006.exe
I have completed some tests on my Hard drive with the below software,
CrystalDiskMark - Software - Crystal Dew World
My Hard drive is .................
VelociRaptor Western Digital VelociRaptor WD1500HLFS 150GB 10000 RPM 16MB Cache SATA 3.0Gb/s 3.5"
I have been told this is very slow compared to a SSD SATA 111 [ My Rampage 11 extreme only supports SATA 11 but will down grade a SATA 111
Any reasons why these results look slow , I thought the Hard drive was quite a speedy thing.
Thanks
Gary
You may use a signature (commonly used in email messages) in your posts. You can specify in your profile a signature to use at the bottom of your posts. When you post, there is an option to use your signature. A signature may contain one or more images but they must fit within a box with maximum dimensions of 400 x 75 pixels (width x height) and with a maximum (combined) file size of 20k. Images containing mostly very large words or animated .gifs will not be permitted. You may also add 1 consecutive lines of normal or smaller text directly above or underneath the image with no spaces inbetween image and text. If no images are used then up to 4 consecutive lines of normal or smaller text is permitted. Do not pad out your text lines with blanks lines. A line of text is defined as having a maximum length of 400 pixels. If you want to turn the signature off in the future, you can come back and edit your post. If you have specified a signature in your profile, the box will be automatically ticked for you.
Hi LexLuthor.
Fix your signature please.
You're only allowed 4 lines of text.
Done..
Best regards..![]()
Thanks
You didn't have to remove it all, just trim it a bit.
It's hard to put it in only 4 lines..![]()
