- 3 Jul 2007
- Newcastle UK
Just after some advice as I have been out of the loop for a while.
My friend's laptop has given up and hes thinking of going for a desktop due to better performance for the price and no need to really be mobile with it.
His main uses are web browsing and occasionally gaming. Football Manager at the moment (not sure how graphics intensive that is?) but the ability to play other games is also beneficial.
His budget is around the 400.00 mark but prepared to stretch that if its worthwhile. So id say 400-500 mark.
I was thinking about
Intel i5
Mobo- not sure what chipset. Any recommendations?
4-8gb of ram
500gb HDD SATA OR a small solid state giving the ability to add another internal HDD at a later date.
GPU- Probably an ATI 6600 series (whatever the budget will stretch to)
PSU- Something reliable to run the above id imagine it'll have to be 500W+?
Case- Something cheap and cheerful
Optical- Just a dvd rw sata.
Network- An internal card to pick up his wifi signal.
Im assuming a dedicated GPU will beat integrated graphics on the mobo. Hence going for a card rather than just the mobo's onboard?
Any printscreen specs/suggestions or advice would be great.
Thanks
Intel i5
4-8gb of ram
Thanks
