... but it doesn't mean you are eating too much carp![]()
I was under the impression that carp was a good fish to eat because it is cheap and sustainable
I was under the impression that carp was a good fish to eat because it is cheap and sustainable![]()
I was using a small bit of wood to put heels on to see if I could improve the drive through the heels. I will consider losing the trainers, thanks![]()
I posted a video before but it didn't show very good angles so I got another one which is some what better. How is my form? It looks kind of OK to me but I am never sure. Was harder than usual due to a bit of a bad hip from kick boxing in the week![]()
Do not put something under your heals!I was using a small bit of wood to put heels on to see if I could improve the drive through the heels. I will consider losing the trainers, thanks![]()
It only happens on 2 of the reps, so it isn't too bad.
Everything will change when he removes the wood and the heel from his trainers, so it's almost pointless giving extra critique on that set.
It's good that you're catching these things! But it is possible to be too anal about these things. That minor level of tuck is more a product of control and awareness, and as I said a lot will change without the assisted ankle ROM.
