It worked! Although it was a close shave![]()
You could set up a little booth outside of a Samsung pop up store and charge people £2 to do theirs, actually no it's London £20!!
Other than that though, one could argue the design of the One X (edit!) is more pleasing to look at which is probably true actually but it's not a comfortable phone to hold at any angle due to the sharp edges.
All you can eat = AYCE
Edit*
I'll have a go with the cutter, Chinese build quality best not do me over today!
Edit**
LOL seriously I know your a huge Samsung fanboi but have u even held a One X??? Because quite clearly your comments prove you havent...the one X doesn't have any sharp edges, i'm sat here holding mine and I don't know where you get this notion that it has sharp edges and it's not comfortable to hold at any angle. You sure your not talking about the iphone4 or 4s as they have sharp edges and are uncomfortable to hold...i should know as I had one for a couple of yrs ie the iphone4. Unless you have girly hands lol and cant stand sharp objects in your hands, which in that case there's no helping you
Compared to the SGS3, the one X is just as nice to hold...my criticism the SGS3 is that it's a slightly heavier phone which I don't know is a good thing or bad thing...plus the one X is slightly taller when I held them together.
But that's not say the SGS3 is a pile of **** because it isn't, it's a very nice phone to hold but personally I think the one X is a slightly better looking phone and feels nicer in the hand.
As I said I know your a huge Samsung fanboi but at least be a bit objective in your criticism dude![]()
Mm you would need to find 2 years of contract at 130 quid to be the t-mobile deal though.
I am due an upgrade now from my iphone4.. this is the only phone that takes my fancy. Is there anything about this phone that makes it worse than the htc1x?
Also.. how do you get your music onto it? is it easy ? is there lots of faffing around etc?
And have any of converted from the apple ecosystem to this and found any issues?
Mobiles.co.uk are offering it for free now on T-Mobile for £26/month
300 mins Any Network Anytime
+ Unlimited Texts + 750MB data.
Hold the X, the creases around the sides and the corners, they're sharp andcan feel uncomfortable holding it for a length of time like when gaming.
As in, the edges are not curved and smooth like previous HTC phones.
Sharp doesn't necessarily mean it will cut you know! It's not smooth and seamless so therefore it is sharp.
The One S is exactly the opposite, it is perfect for long periods of gaming or whatever else requires holding the phone for a while.
Did they mention anything about stock? If you asked that is!
If not then a note to others over the next few days of you go down, please ask about stock availability!
Damn you!
Well Play have not emailed about any delay so I can only imagine that things are still on call for the 30th!
CPW policy is not to tell stores the time that stock is due to arrive for security purposes apparently, that's what CPW in Hedge End told me anyway.
