*** Official OcUK Minecraft Server - Discussion and Rules ***
Indeed PoD, this will be a problem if it isn't up by tonight! We could do the testing on my machine again but it may have a just-noticeable lag to it.
Hi. I've just started the hardcore server again. I've no idea what happened with it. Sorry for the issues. Luckily trix emailed me just as I arrived back home.
i'd be up for a fresh start with some new mods, not been on for a while as i'm kind of at a loss for build ideas at the moment, i'm sure some new content in the form of mods would be benificial.
i'm not really fussed about having my build transferred, however if this did happen is there anyway to take the resourses used for the build over with me without having to dismantle it block by block?
What kind of updates? I brought the server up (as posted above) and as far as I know it is working and people are playing on it?
Ah, they were trying to change the config files a while ago but it didn't work so the event went ahead anyway. :)
It was pretty cool, Maxi and Saf destroyed me though lol.
There were a few bits that needed changing but the main one was to disable health regen, unless you get a golden apple then you regen 2 hearts.
yeh i have no idea what happened with the config, i'l have another look at it - but it was the same one that i had on my server :S Don't suppose there is any way I can remotely access just the hardcore server files and work it out? - don't want you to spend your time on it if possible ^^
My worry is how easily it becomes to trade for what you want.
I could literally have 100's of diamond picks with the resources at my disposal.
It is silly to be able to get such a MASSIVE advantage with little to know exploration.
if it is a fresh start you wont :P
but i know what you meen.
But in saying that you could anyway but you will need emeralds forst to start the trading process as they go from emralds to basic resorces over time.
I can get you access to that directory yeah. I'll get on it today and PM you details on linktart.
I don't see why it couldn't be used as the map for the next hardcore match but the final decision really rests with the admins/hc-mode-admins that will be organising it :) I'm happy to support it from a config/file upload point of view though.
