I think I just got the deal of the century....
kd
That chest armour will be worth a bit. Can't quite say how much, but 1000k+ pretty easily I'd say.
The other two might suffer because they have no Res All. But the Phys res on that shield should give it a good value too, especially considering it's armour value.
No idea about the wiz helm, don't keep an eye on that stuff.
Best bet is to look for similar stat stuff to be honest...
kd
dual wielding alternates between weapons with a slightly better APS (15% I think), if your off-hand weapon is much lower damage/dps than your primary, replacing it with a shield could actually increase your dps as every hit is coming from the more powerful weaponI am really confused with this game.
I am playing on NM,level 40 Monk and I was dual wielding until now.I picked up a blue shield which gives +44 vit and NOTHING else.I am swapping the shield with one of my rare fists (which gives +dex,crit and a bunch of stuff)and boom,+100 dps.How is that possible?What's the purpose of dual wielding then?How can a fist and a shield make more dmg than 2 fists!?
Where can I purchase a CD key or reasonably priced boxed version? Lots of places are sold out or asking silly money.
Mats aren't really the problem, it's the 50k to craft for a total random item. By the time you get something good unless you're super lucky, could have just bought it on the AH.If you want inferno mats just salvage lvl 60 gear, most stuff under 60 will give you hell mats.
Same question - not paying £44 or whatever it is for a download for starters! CE is crazy money as well.![]()
yeah if it had attack speed it would be worth loads![]()
Don't focus on lifesteal (% of damage done to life) if you're wanting to progress in inferno. The effectiveness of that effect is reduced by 80% in inferno difficulty. Life on hit is where it is at for Barbs along with the usual defensive stats (resists, armor, reduced damage from elites)
